Protect your laptop, dock or other device against theft while enhancing productivity with this laptop cable lock, providing a full range of motion. The laptop anti-theft lock has a 4-digit resettable combination for enhanced security at the office or on the go.
While your laptop, dock or other device is secured with the locking cable, you can move your device freely. The swivel hinge allows motion in two directions - the hinge rotates 360 degrees around the lock head, and pivots 90 degrees for easy locking and unlocking.
Choose your own combination so you can remember it easily. Or, prevent others from knowing your passcode by changing it often. The 4-digit combination security cable lock is easy to change.
Ensure that your laptop or other device is protected wherever you work. The 2 m(6.5') locking cable helps to prevent theft in areas with high foot traffic including a wide range of retail, commercial, educational and institutional environments. The cable lock is compatible with devices equipped with the industry-standard Kensington lock slot (K-Slot).
Ideal for use at the office or when travelling, the portable combination laptop lock features a strong vinyl-coated steel cable (4.4 mm diameter). To secure your device in different work spaces, the flexible steel cable bends easily to loop around a stationery post or object.
- StarTech.com 6.5ft (2m) Laptop Cable Lock, 4 Digit Combination Laptop/Desktop Security Cable Lock for K-Slot Devices/Computers/Monitors, Portable Anti-Theft Vinyl Coated Steel Cable Lock - K Slot Laptop Lock (LTLOCK4D) - security cable lock
- Product Type
- Security cable lock
- Product Material
- Vinyl-coated steel
- 5.51 cm x 2 m x 1.6 cm
- Length
- 2 m
- 128 g
- Combination lock, 4 digit code, anti-theft protection, kensington security slot, swivel hinge
- 2-year warranty
- Product Type
- Product Material
- 5.51 cm
- 2 m
- 1.6 cm
- Length
- 2 m
- 128 g
- Limited warranty: - 2 years
StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit Combination | In Stock | £17.93 |
StarTech.com Keyed Cable Lock - Push-to-Lock Button - 2 m / 6.5’ Cable | In Stock | £21.32 |
StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable | In Stock | £7.40 |
StarTech.com Laptop Cable Lock - 4-Digit Resettable Combination Lock - For Wedge Lock Slot | In Stock | £27.09 |
