StarTech.com Lap Desk - For 13" / 15" Laptops - Portable Lap Pad
Quicklinx: FLYLWS00 Mfr#: NTBKPAD
Device Type: Laptop
Type: Portable Lapdesk
Device Screen Size: 13 - 15
Colour: Grey, Black
£20.34 ex VAT
£24.40 inc VAT
Work with greater comfort and productivity, wherever you go, with this ergonomic portable lap desk. Ideal for 13" and 15" laptops, it gives you a stable non-slip work surface, with a retractable mouse pad.
With its sturdy design and light weight (just 2.2 lb. / 0.5 kg), the portable laptop lap pad tucks easily into your notebook bag.
Now when you're commuting or travelling for business, instead of adapting to your environment, adapt your environment to you. The travel lap desk provides a solid work surface to let you work in comfort in the airport, on the train, out in the field, or wherever work takes you.
Simply slide the mouse tray out, to provide ample space to use your mouse (6.1" x 7.3" / 15.5 cm x 18.5 cm). The laptop lap desk with retractable mouse pad extends on either side, working equally well for right or left-handed users. The bottom edge of the mouse pad is slightly raised to help prevent your mouse from sliding off.
Maximize your work time, with no worries of your laptop sliding. The textured silicone surface on the computer lap tray keeps your laptop in place on the lap desk.
The silicone top surface of the notebook lap pad also provides a heat-resistant barrier. It helps to prevent thermal transfer from your laptop to your body while working. It lets you stay cool, to work in comfort.
StarTech.com Lap Desk - For 13" / 15" Laptops - Portable Notebook Lap Pad - Retractable Mouse Pad - Anti-Slip Heat-Guard Surface (NTBKPAD) - notebook pad - TAA Compliant
Notebook pad
Black, grey
Product Material
Plastic, silicone
36 cm x 25 cm x 1.5 cm
1.025 kg
Notebook Compatibility
15"
Notebook Supported Sizes
13" - 15" / 33 cm - 38.1 cm
Retractable mouse pad, anti-slip base, heat-resistant
TAA Compliant
Notebook pad
Product Material
Plastic, silicone
36 cm
25 cm
1.5 cm
1.025 kg
36 cm x 26 cm x 2.2 cm / 1.04 kg
15"
Black, grey
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
Device Type: Laptop
Colour: Grey
Colour: Black
