StarTech.com KVM Console to USB 2.0 Portable Laptop Crash Cart Adapter
Quicklinx: 660NWS00 Mfr#: NOTECONS01
Type: KVM Extender
Hurry, only 3 left in stock!
£379.59 ex VAT
£455.50 inc VAT
Turn any laptop into a console for headless servers, PCs, ATMs, Kiosks and more! StarTech.com's USB 2.0 Laptop KVM Adapter turns your notebook or netbook into a guininely portable server crashcart, eliminating the need to lug around a large, heavy and awkward video screen, keyboard, and mouse. This adapter delivers the VGA stream from any host computer to a laptop and emulates the laptop mouse and keyboard outputs, for simple access and control of connected servers, PCs or other "headless" devices.
With portability for the mobile administrator or repair technician in mind, this self-powered adapter features a small-footprint design that requires no additional accessories to connect to most servers, and requires no server-side software installation. Plus, the pocket-sized adapter draws its power from the server-side connections, allowing the laptop/netbook to last longer without consuming battery power.
Ensuring full control of the connected units, the Laptop KVM Server Console Adapter provides immediate access to the BIOS post and the ability to handle full configuration of the attached PC or machine; administrators can connect to a headless server/device without the need of an expensive LCD rackmount console or bulky monitor, keyboard, and mouse solution.
  • Efficient connectivity
    This adapter features various cable types, including USB and VGA, allowing for versatile installation options in different setups.
  • Clear video output
    With a maximum supported video resolution of 1920 x 1600 and a V-Sync rate of 60 Hz, this adapter ensures that visual output remains sharp and fluid.
  • Environmental robustness
    Designed to operate within a temperature range of 0°C to 40°C, this adapter is built to withstand various environmental conditions.
StarTech.com Crash Cart Adapter - 1920 x 1200 - Portable Laptop USB 2.0 to KVM Console (NOTECONS01) - KVM switch - 1 ports
Subtype
KVM
Ports
1 x KVM port(s)
KVM Users Qty
1 local user
Firmware upgradable
7.4 cm x 11.5 cm x 1.5 cm
172 g
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux 2.6 or later, Linux LTS versions only
Enclosure Type
Desktop
Subtype
KVM
Ports
1 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1920 x 1600 @ 60 Hz
Firmware upgradable
Status Indicators
Link/activity
Keyboard / video / mouse (KVM): 1 x 4 pin USB Type A , 1 x USB Type A , 1 x keyboard (PS/2) , 1 x VGA HD-15
1 x USB host cable - 38.5 cm , 1 x USB cable - 1.8 m , 1 x VGA cable - 7.6 cm
FCC, RoHS
7.4 cm
11.5 cm
1.5 cm
172 g
660N StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.25
660N StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £24.28
660N StarTech.com KVM Console to Laptop USB 2.0 Portable Crash Cart Adapter with File Transfer In Stock £392.84
660N StarTech.com Laptop to Server KVM Console In Stock £446.66
660N StarTech.com 17.3" Laptop Backpack w/ Case In Stock £106.98
Type: KVM Extender
