Turn any laptop into a console for headless servers, PCs, ATMs, Kiosks and more! StarTech.com's USB 2.0 Laptop KVM Adapter turns your notebook or netbook into a guininely portable server crashcart, eliminating the need to lug around a large, heavy and awkward video screen, keyboard, and mouse. This adapter delivers the VGA stream from any host computer to a laptop and emulates the laptop mouse and keyboard outputs, for simple access and control of connected servers, PCs or other "headless" devices.
With portability for the mobile administrator or repair technician in mind, this self-powered adapter features a small-footprint design that requires no additional accessories to connect to most servers, and requires no server-side software installation. Plus, the pocket-sized adapter draws its power from the server-side connections, allowing the laptop/netbook to last longer without consuming battery power.
Ensuring full control of the connected units, the Laptop KVM Server Console Adapter provides immediate access to the BIOS post and the ability to handle full configuration of the attached PC or machine; administrators can connect to a headless server/device without the need of an expensive LCD rackmount console or bulky monitor, keyboard, and mouse solution.
Efficient connectivity
This adapter features various cable types, including USB and VGA, allowing for versatile installation options in different setups. -
Clear video output
With a maximum supported video resolution of 1920 x 1600 and a V-Sync rate of 60 Hz, this adapter ensures that visual output remains sharp and fluid. -
Environmental robustness
Designed to operate within a temperature range of 0°C to 40°C, this adapter is built to withstand various environmental conditions.
- StarTech.com Crash Cart Adapter - 1920 x 1200 - Portable Laptop USB 2.0 to KVM Console (NOTECONS01) - KVM switch - 1 ports
- Subtype
- KVM
- Ports
- 1 x KVM port(s)
- KVM Users Qty
- 1 local user
- Firmware upgradable
- 7.4 cm x 11.5 cm x 1.5 cm
- 172 g
- Black
- System Requirements
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux 2.6 or later, Linux LTS versions only
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 1 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2, USB
- Max Resolution
- 1920 x 1600 @ 60 Hz
- Status Indicators
- Link/activity
- Keyboard / video / mouse (KVM): 1 x 4 pin USB Type A , 1 x USB Type A , 1 x keyboard (PS/2) , 1 x VGA HD-15
- Black
- Cables Included
- 1 x USB host cable - 38.5 cm , 1 x USB cable - 1.8 m , 1 x VGA cable - 7.6 cm
- FCC, RoHS
- OS Required
- 7.4 cm
- 11.5 cm
- 1.5 cm
- 172 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.17 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.45 |
StarTech.com KVM Console to Laptop USB 2.0 Portable Crash Cart Adapter with File Transfer | In Stock | £389.32 |
StarTech.com Laptop to Server KVM Console | In Stock | £433.25 |
StarTech.com 17.3" Laptop Backpack w/ Case | In Stock | £107.54 |
