Easily protect your laptop or other device against theft, using this keyed cable lock. With a convenient push-to-lock function and no combination required, the steel cable laptop lock maximizes security at the office or on the go.
Save time every day with the push-to-lock button. Just one press and the lock is set. Plus, for convenient operation, the cable joint swivels 360 degrees.
Easily lock and unlock the laptop cable with the provided keys. Two identical keys are provided, to ensure you always have a spare.
Ensure that your laptop, tablet, dock, smartphone or other device is anchored safely to your workspace. This keyed cable lock features a durable zinc-alloy lock head. To provide dependable theft protection in a wide range of retail, commercial, and institutional environments, the 2 m(6.5'.) locking cable is compatible with laptops or other devices equipped with the industry-standard Kensington lock slot (K-Slot).
Ideal for portable use or at the office, the computer cable lock features a strong vinyl-coated steel cable (4.4 mm diameter). To secure your device in a variety of different work spaces, the flexible steel cable bends easily to loop around a stationary post or object.
Strong construction
The use of vinyl and steel in this security cable lock ensures long-lasting durability and resistance to tampering or cutting. -
Versatile design
The 360° swivel capability allows for flexible positioning, making it simple to secure laptops and other devices in various environments.
- StarTech.com 6ft (2m) Laptop Cable Lock with Keys, Keyed Security Cable Lock for Compatible K-Slot Laptops, Desktops, Computers & Other Devices, Anti-Theft Vinyl Coated Steel Cable Lock - 6 ft Keyed Cable Lock (LTLOCKKEY) - security cable lock
- Product Type
- Security cable lock
- Black, silver
- Product Material
- Vinyl, steel
- 3.2 cm x 2 m x 1.7 cm
- Length
- 2 m
- 130 g
- 360 degree swivel capability
- 2-year warranty
- Product Type
- Product Material
- Vinyl, steel
- 3.2 cm
- 2 m
- 1.7 cm
- Length
- 2 m
- 130 g
- Black, silver
- Limited warranty: - 2 years
