StarTech.com K-Slot Cable Lock, 5ft (1.5m)
Quicklinx: J1KHWS00 Mfr#: SSTDC4D-LAPTOP-LOCK
More than 50 In Stock
£13.33 ex VAT
£15.99 inc VAT
The Slim Lock K-Slot Compatible 6.6 ft Combination Locking Cable provides security for notebook, ensuring peace of mind against theft. Constructed from durable plastic and steel materials, this security cable lock features anti-theft protection and is cut-resistant, making it a reliable choice for safeguarding valuable devices. The design includes a hook-and-loop fastening strap for easy storage and transport, while the 360° rotation adds flexibility for various setups. With a standard lock method that utilizes a combination for access, this product is compliant with the Kensington Standard Slot (K-Slot), ensuring compatibility with a wide range of devices.
  • Robust security
    This security cable lock offers anti-theft protection specifically designed for notebooks, providing reliable defense against theft.
  • Durable design
    Constructed from plastic and steel, this locking cable is engineered to withstand tampering and resist damage.
  • Flexible positioning
    With the ability to rotate 360°, this cable allows users to position their devices securely in various configurations.
  • Easy compatibility
    The Slim Lock is designed to work seamlessly with devices that have a Kensington Standard Slot (K-Slot), ensuring versatile usage.
  • Portable convenience
    The included hook-and-loop fastening strap allows for easy storage and transport, making it convenient to carry on the go.
StarTech.com Slim Lock K-Slot Compatible, 6.6ft Combination Locking Cable - security cable lock
Security cable lock
Package Content
Hook-and-Loop fastening strap
Black & silver
Product Material
Steel, plastic
15 cm 2.2 cm
Length
2 m
105 g
Kensington Standard Slot (K-Slot), 360° rotation, anti-theft protection, cut-resistant
Security cable lock
Product Material
Steel, plastic
Package Content
15 cm
2.2 cm
Length
2 m
105 g
5.4 cm x 1.6 cm x 2 cm
Black & silver
Security Cable Lock
Intended For
Notebook
Lock Type
Standard
Lock Method
Combination
TAA Compliant
Limited warranty: - 2 years
