The Slim Lock K-Slot Compatible 6.6 ft Combination Locking Cable provides security for notebook, ensuring peace of mind against theft. Constructed from durable plastic and steel materials, this security cable lock features anti-theft protection and is cut-resistant, making it a reliable choice for safeguarding valuable devices. The design includes a hook-and-loop fastening strap for easy storage and transport, while the 360° rotation adds flexibility for various setups. With a standard lock method that utilizes a combination for access, this product is compliant with the Kensington Standard Slot (K-Slot), ensuring compatibility with a wide range of devices.
Robust security
This security cable lock offers anti-theft protection specifically designed for notebooks, providing reliable defense against theft. -
Durable design
Constructed from plastic and steel, this locking cable is engineered to withstand tampering and resist damage. -
Flexible positioning
With the ability to rotate 360°, this cable allows users to position their devices securely in various configurations. -
Easy compatibility
The Slim Lock is designed to work seamlessly with devices that have a Kensington Standard Slot (K-Slot), ensuring versatile usage. -
Portable convenience
The included hook-and-loop fastening strap allows for easy storage and transport, making it convenient to carry on the go.
- StarTech.com Slim Lock K-Slot Compatible, 6.6ft Combination Locking Cable - security cable lock
- Product Type
- Security cable lock
- Package Content
- Hook-and-Loop fastening strap
- Black & silver
- Product Material
- Steel, plastic
- 15 cm 2.2 cm
- Length
- 2 m
- 105 g
- Kensington Standard Slot (K-Slot), 360° rotation, anti-theft protection, cut-resistant
- 2-year warranty
- Product Type
- Product Material
- Steel, plastic
- Package Content
- 15 cm
- 2.2 cm
- Length
- 2 m
- 105 g
- Shipping Dimensions (WxDxH) / Weight
- 5.4 cm x 1.6 cm x 2 cm
- Black & silver
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- Standard
- Lock Method
- Combination
- TAA Compliant
- Limited warranty: - 2 years
