The SFPGE10KT3R4 is a Juniper SFP-GE40KT13R15 compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-BX10-U compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Juniper SFP-GE10KT13R14 Compatible SFP Module, 1000BASE-BX-U, 1 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP, LC 10km, Mini GBIC Transceiver SFP, Upstream - Lifetime Warranty (SFPGE10KT3R4) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-BX10-U
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 (TX) / 1490 (RX) nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Juniper SFP-GE10KT13R14
- 1.4 cm x 6.5 cm x 1.2 cm
- 72 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-BX10-U
- 1GbE
- 1 Gbps
- 10 km
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 1000Base-BX10-U - LC single-mode female
- MTBF
- 3,713,222 hours
- FCC, RoHS, REACH, MSA
- 1.3 Watt
- 1.4 cm
- 6.5 cm
- 1.2 cm
- 72 g
- Shipping Width
- 20.7 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 80 g
- Limited warranty - lifetime
