StarTech.com Juniper SFP-1GE-FE-E-T Comp SFP Copper Module - 10/100/1000B
Quicklinx: FKF7WS00 Mfr#: SFP1GEFEETST
1000 Mbps (1 Gbps) Copper RJ-45 100 m (328 ft) Lifetime Warranty. The SFP1GEFEETST is a Juniper SFP-1GE-FE-E-T compatible copper transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 10/100/1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
Technical Specifications:
Maximum Data Transfer Rate: 1000 Mbps (1 Gbps)
Type: Copper
Connection Type: RJ-45
Maximum Transfer Distance: 100 m (328 ft)
MTBF: 4,655,371 hours
Power Consumption: Low power consumption
Digital Diagnostics Monitoring (DDM): No
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com SFPs
All StarTech.com SFP & SFP+ transceiver modules are backed by a lifetime warranty and free lifetime multilingual technical support. StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper SFP-1GE-FE-E-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1Gbps/1000Mb Mini GBIC Transceiver SFP Module - Lifetime Warranty (SFP1GEFEETST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1.25 Gbps
1GbE
Max Transfer Distance
100 m
1.4 cm x 6.5 cm x 1.2 cm
72 g
Plug-in module
Wired
Cabling Type
1GbE
Data Transfer Rate
1.25 Gbps
100 m
Full duplex mode
IEEE 802.3
1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female
MTBF
4,655,371 hours
FCC, RoHS, REACH, MSA
1.4 cm
6.5 cm
1.2 cm
72 g
Shipping Width
20.7 cm
Shipping Depth
23 cm
Shipping Height
1.5 cm
Shipping Weight
80 g
Limited warranty - lifetime
