The SFP1FEFXST is a Juniper SFP-1G-ZC compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 100Base-FX compliant networks, with a maximum distance of up to 80 km (49.7 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Juniper SFP-1FE-FX Compatible SFP Module, 100BASE-FX, 100MbE Multimode Fiber MMF Optic Transceiver, 100Mb Ethernet SFP, LC Connector, 2km, 1310nm, DDM, 100Mb Mini GBIC Module - Lifetime Warranty (SFP1FEFXST) - SFP+ transceiver module - 100Mb LAN
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-FX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 2 km
- OEM Manufacturer Equivalent Part Number
- Juniper SFP-1FE-FX
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-FX
- 100Mb LAN
- 100 Mbps
- 1310 nm
- 2 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 100Base-FX - LC multi-mode female
- MTBF
- 1,472,572 hours
- MSA
- Limited warranty - lifetime
StarTech.com Juniper SFP-1FE-FX Compatible SFP MM Module - 100Base-FX
