StarTech.com Juniper SFP-1FE-FX Compatible SFP MM Module - 100Base-FX
Quicklinx: FJNNWS00 Mfr#: SFP1FEFXST
The SFP1FEFXST is a Juniper SFP-1G-ZC compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 100Base-FX compliant networks, with a maximum distance of up to 80 km (49.7 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper SFP-1FE-FX Compatible SFP Module, 100BASE-FX, 100MbE Multimode Fiber MMF Optic Transceiver, 100Mb Ethernet SFP, LC Connector, 2km, 1310nm, DDM, 100Mb Mini GBIC Module - Lifetime Warranty (SFP1FEFXST) - SFP+ transceiver module - 100Mb LAN
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
Juniper SFP-1FE-FX
Plug-in module
Wired
Cabling Type
100Base-FX
100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 100Base-FX - LC multi-mode female
MTBF
1,472,572 hours
MSA
Juniper SFP-1FE-FX
Limited warranty - lifetime
