StarTech.com Juniper RX-550M-SFP Compatible SFP MM Module - 1000Base-SX -
Quicklinx: FJNBWS00 Mfr#: RX550MSFPST
£5.74 ex VAT
£6.88 inc VAT
The RX550MSFPST is a Juniper RX-70KM-SFP compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-SX compliant networks, with a maximum distance of up to 70 km (43.5 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper RX-550M-SFP Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, Mini GBIC Module - Lifetime Warranty (RX550MSFPST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
Juniper RX-70KM-SFP
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MTBF
53,972,659 hours
MSA
Juniper RX-70KM-SFP
Limited warranty - lifetime
