StarTech.com Juniper RX-10KM-SFP Comp SFP SM / MM Module - 1000Base-LX
Quicklinx: FJN9WS00 Mfr#: RX10KMSFPST
The RX10KMSFPST is a Juniper RX-550M-SFP compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000BASE-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper RX-10KM-SFP Compatible SFP Module, 1000BASE-LX, 1GbE Single/Multi Mode MMF Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector 10km, 1310nm, DDM, Mini GBIC - Lifetime Warranty (RX10KMSFPST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode / LC multi-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Juniper RX-10KM-SFP
Plug-in module
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-LX - LC single-mode / LC multi-mode female x 2
MTBF
53,972,659 hours
MSA
Juniper RX-10KM-SFP
Limited warranty - lifetime
