Add reliable and cost-effective 10 Gigabit Ethernet connections over multimode fiber with this SFP+ module. This StarTech.com 10 Gigabit fiber SFP+ is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Juniper Networks switches and routers that support the Juniper EX-SFP-10GE-SR SFP+ transceiver module, as well as other major brands of networking equipment.
The 10GBase-SR SFP+ delivers 10 Gigabit connectivity over multimode fiber cable with a range of up to 300 m (984 ft). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The 10 Gigabit multimode SFP+ is engineered to the highest quality standards and is 100% Juniper compatible, equivalent to the Juniper EX-SFP-10GE-SR SFP+ transceiver. The StarTech.com SFP+ is configured and fully tested to ensure it works seamlessly with Juniper or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP+ products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a wide range of 10 Gigabit networking devices.
Ideal for use in Juniper switches, routers and other networking equipment, the SFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The multi-mode fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 300 m (984 ft), and maximum data rates of up to 10Gbps.
- StarTech.com Juniper EX-SFP-10GE-SR Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 300m, 850nm, DDM, Mini GBIC - Lifetime Warranty (EXSFP10GESRS) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- OEM Manufacturer Equivalent Part Number
- Juniper EX-SFP-10GE-SR
- 1.39 cm x 5.84 cm x 1.26 cm
- 30 g
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 10 Gbps
- 850 nm
- 300 m
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3ae
- 1 x Ethernet 10GBase-SR - LC multi-mode female x 2
- UL, FCC, RoHS, MSA
- 1.39 cm
- 5.84 cm
- 1.26 cm
- 30 g
- 0 °C
- 70 °C
- 5 - 95%
