StarTech.com Juniper CTP-SFP-1GE-T Comp SFP Copper Module - 1000Base-T -
Quicklinx: FJMPWS00 Mfr#: CTPSFP1GETST
Type: Modules
£16.03 ex VAT
£19.23 inc VAT
The CTPSFP1GETST is a Juniper CTP-SFP-1GE-T compatible copper transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper CTP-SFP-1GE-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1Gbps/1000Mbps Mini GBIC Transceiver SFP Module - Lifetime Warranty (CTPSFP1GETST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
Plug-in module
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
100 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-T - RJ-45 female
MTBF
4,655,371 hours
MSA
Limited warranty - lifetime
Type: Modules
