The J9151A-BX-U-ST is an HP J9151A compatible upstream fiber SFP+ transceiver which pairs with StarTech.com's J9151A-BX-D-ST. They are designed, programmed and tested to work with 10GBase-BX compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ Cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com HPE J9151A Compatible SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP+, LC 10km, HPE 2920, 2910al, 3500yl, Mini GBIC Transceiver - Lifetime Warranty (J9151A-BX-U-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-BX
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1270 nm / 1330 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- HP J9151A-BX-U
- 5.84 cm x 1.39 cm x 1.26 cm
- 24 g
- Limited lifetime warranty
- Designed For
- HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-BX
- 10GbE
- 10 Gbps
- 1270 nm / 1330 nm
- 10 km
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-BX - LC single-mode female
- MSA
- HP J9151A-BX-U
- 1.3 Watt
- 5.84 cm
- 1.39 cm
- 1.26 cm
- 24 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
- Designed For
- HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl , HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
