The StarTech.com 16-Port Industrial USB 5Gbps Hub is engineered to meet the demands of high-performance data environments, offering a robust solution for industrial settings. This hub is encased in a metal enclosure, providing not only durability but also ESD protection to safeguard against electrical surges and shocks. With 16 USB 3.2 Gen 1 ports, it delivers high-speed data transfer rates up to 5 Gbps, ensuring efficiency in operations.
Designed for versatility, it supports multiple mounting options including DIN rail, desktop, rack-mountable, and wall-mountable configurations, making it suitable for a variety of workspace setups. The inclusion of an external power adapter with 160 W of power ensures that all connected devices receive sufficient charging. Furthermore, its unique dual-host switch feature allows for seamless sharing between two host devices, enhancing its utility in complex setups. With a commitment to reliability, this USB hub is an essential tool for expanding connectivity in demanding industrial environments.
Robust design
Encased in a durable metal housing and designed for industrial environments, this 16-Port USB hub ensures reliability and longevity with ESD protection against electrical shocks and surges. -
Versatile mounting options
With options for DIN rail, desktop, rack-mountable, and wall-mountable setups, this USB hub offers flexible installation to meet the demands of any workspace. -
High-speed connectivity
Supports USB 3.2 Gen 1 technology, allowing for data transfer rates up to 5 Gbps, making it ideal for high-speed data transmission requirements. -
Enhanced power delivery
Comes with an external power adapter providing 160 W of power, ensuring that connected devices are charged efficiently and reliably. -
Dual-host switching
Features a dual-host switch that enables two host devices to share the USB hub, enhancing peripheral sharing and flexibility in device management.
- StarTech.com 16-Port Industrial USB 5Gbps Hub with Power Adapter, Metal Enclosure, Mountable, ESD Protection, Terminal Block Power, USB Charging, Dual-Host Switch - TAA - hub - 16 ports - rack-mountable - TAA Compliant
- Hub - 16 ports
- Enclosure Type
- Rack-mountable 1U
- Subtype
- USB
- Ports
- 16 x USB 3.2 Gen 1
- Performance
- Data transfer rate: 5 Gbps
- Screw lock, over-current protection, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), switch button, fast charging support
- USB 3.0, USB 3.2 Gen 1, Battery Charging 1.2
- Power
- AC 100-240 V
- 1.1 kg
- Black
- TAA Compliant
- 2-year warranty
- Hub - 16 ports
- Enclosure Type
- Desktop, rack-mountable, DIN rail mountable, wall-mountable 1U
- Subtype
- USB
- Ports
- Performance
- Processor
- 1 x Genesys Logic GL3523
- Status Indicators
- Power, host
- 16 x USB 3.2 Gen 1 Type A , 2 x USB 3.2 Gen 1 Type B host , 1 x 2 pin terminal block
- Power Device
- External power adapter
- Power Provided
- 160 Watt - DC 24 V - 6.6 A
- Voltage Required
- AC 100-240 V
- 158.4 Watt
- Black
- Included Accessories
- Mounting screws, terminal block connector, 2 DIN-rail mounting brackets
- Cables Included
- 1 x USB-A to USB-B cable - 3 m
- MTBF
- 122,383.8 hours
- EIA-310-D
- TAA Compliant
- 1.1 kg
- Shipping Width
- 36.8 cm
- Shipping Depth
- 27.3 cm
- Shipping Height
- 9.8 cm
- Shipping Weight
- 1.8 kg
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 60 °C
- 5 - 95% RH
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 75 °C
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.76 |
StarTech.com Industrial USB 10Gbps Hub | In Stock | £175.68 |
