The 16-port industrial USB 3.0 hub with 5 Gbps of shared bandwidth provides fast and efficient transfer speeds, making it an ideal solution for data-intensive applications. The hub features a 2-port host switch, enabling users to switch between two host devices, streamlining device management. The hub also includes ESD protection to safeguard against static electricity. Additionally, the hub supports USB BC 1.2, enabling fast charging of battery-powered USB devices. The combined features of this USB hub ensure stable and reliable functionality for use in IT and industrial applications.
Engineered for use in industrial environments
This USB hub is built to withstand harsh industrial environments. It features a rugged steel housing that provides protection against physical hazards such as drops and impacts. It is equipped with Level-4 ESD protection, with 15 kV air and 8 kV contact discharge ratings, to safeguard against damage caused by static electricity. These features make the USB hub an excellent choice for use in factories, production lines, and other industrial settings. -
Connect and charge USB devices
This USB hub features two 12-24 V DC power options. Power can be inputted using the 2-wire terminal block connector or the barrel connector. Both options enable support for USB Battery Charging Specification 1.2 (BC 1.2) with 120 W shared across all ports. Ports are grouped in 8 pairs and each pair supports max 3.0 A/15 W combined (1.5 A/7.5 W per port), or max 2.0 A/10 W per port when only one of both ports is used. -
Dual-host switch
The USB hub can connect to two separate desktop or laptop computers, and features a dual-host switch that enables easy toggling between them. The dual-host switch provides a convenient solution for applications requiring two host devices.
- StarTech.com 16-Port Industrial USB 3.0 Hub 5Gbps, Metal, DIN/Surface/Rack Mountable, ESD Protection, Terminal Block Power, up to 120W Shared USB Charging, Dual-Host Hub/Switch (5G16AINDS-USB-A-HUB) - hub - industrial - 16 ports - rack-mountable
- Hub - 16 ports
- Enclosure Type
- Rack-mountable 1U
- Subtype
- USB
- Ports
- 16 x USB 3.2 Gen 1
- Performance
- Data transfer rate: 5 Gbps
- Screw lock, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), switch button, fast charging support
- USB 3.0, USB 3.2 Gen 1, Battery Charging 1.2
- 28 cm x 13 cm x 4.3 cm
- 1.1 kg
- Black
- 2-year warranty
- Hub - 16 ports
- Enclosure Type
- Desktop, rack-mountable, DIN rail mountable 1U
- Subtype
- USB
- Ports
- Performance
- Processor
- 1 x Genesys Logic GL3523
- Status Indicators
- Power, host
- 16 x USB 3.2 Gen 1 Type A , 2 x USB 3.2 Gen 1 Type B host , 1 x 2 pin terminal block
- Black
- Included Accessories
- Mounting screws, 2 rack mount brackets, terminal block connector, 2 DIN-rail mounting brackets
- Cables Included
- 1 x USB-A to USB-B cable - 3 m
- MTBF
- 122,383.8 hours
- WEEE
- 28 cm
- 13 cm
- 4.3 cm
- 1.1 kg
- Shipping Weight
- 1.8 kg
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 60 °C
- 5 - 95% RH
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 75 °C
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.76 |
StarTech.com Industrial USB 5Gbps Hub | In Stock | £480.51 |
StarTech.com Industrial USB 10Gbps Hub | In Stock | £175.68 |
