StarTech.com Industrial USB 3.0 5Gbps Hub
Quicklinx: H3TYWS00 Mfr#: 5G4AINDNP-USB-A-HUB
Type: USB Hub
Interface: USB-A
Speed: 5Gbps
Ports: 4
Form Factor: External
Hurry, only 2 left in stock!
£92.08 ex VAT
£110.49 inc VAT
Increase USB scalability in industrial environments, product and repair labs, conference rooms or office workstations, using this 4-Port Industrial USB Hub.
  • Functional in Harsh Environments
    This industrial USB hub delivers reliable performance in harsh environments with its heavy-duty, metal housing. It supports 5-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input options. Perfect for factory environments, the rugged hub features ESD/surge protection to each USB port, which aids in preventing damage to any connected devices.
  • Mount to a Wall, Desk or DIN-Rail
    Install the hub where it's best suited for your application. Securely mount the hub to a variety of surfaces, including a wall, desk, or rack, using the built-in mounting brackets and included hardware.
  • Connect and Charge USB Devices
    Designed for a high volume of connections, this robust USB 3.0 hub offers four connection ports, for connecting more USB devices/peripherals. The industrial USB hub supports DC and terminal block power inputs 5 to 24V DC that provide compatibility and flexibility in different scenarios such as product and repair labs, conference rooms, or office workstations. StarTech.com offers external power adapters, ITB20D3250 and SVA12M5NA, sold separately. With the optional power adapter, the hub supports USB battery charging specification 1.2, delivering up to 2.4A on any port to a maximum of 30W total, so you can charge your mobile devices faster than traditional USB ports allow.
  • Wide Device Compatibility
    The hub is OS independent ensuring support on a wide range of platforms including Windows, macOS and Linux. 5G4AINDNP-USB-A-HUB is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual technical support. StarTech.com has been the IT professionals' choice for over 30 years.
StarTech.com 4-Port Industrial USB 3.0 5Gbps Hub, Rugged USB Hub w/15kV Air/8kV Contact ESD and Surge Protection, DIN/Wall/Desk Mountable USB-A Hub, USB Expansion Hub with Locking Ports - Metal Construction (5G4AINDNP-USB-A-HUB) - hub - industrial - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.2 Gen 1
Screw lock, rugged, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), steel housing, integrated mounting bracket, DFP
USB 3.2 Gen 1, Battery Charging 1.2
17.8 cm x 5.9 cm x 2.3 cm
280 g
Hub - 4 ports
Enclosure Type
Desktop, DIN rail mountable, wall-mountable
Subtype
USB
Ports
4 x USB 3.2 Gen 1
X VIA Labs VL817-Q7
Status Indicators
Port status, power
4 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B host , 1 x terminal block
DIN-rail mounting kit, terminal block connector
1 x USB-B to USB-A screw-lock cable - 1.8 m
MTBF
243,753 hours
WEEE, RCM, USB Battery Charging Specification Rev. 1.2
17.8 cm
5.9 cm
2.3 cm
280 g
Shipping Width
21.3 cm
Shipping Depth
14.9 cm
Shipping Height
5.1 cm
Shipping Weight
500 g
Limited warranty - 2 years , Technical support - assistance - lifetime
60 °C
5 - 95% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
75 °C
H3TY StarTech.com Industrial USB 3.0 Hub In Stock £311.13
H3TY StarTech.com Industrial USB 5Gbps Hub In Stock £319.96
Type: USB Hub
Interface: USB-A
Speed: 5Gbps
Ports: 4
