The 7-Port Industrial USB 10Gbps Hub with Power Adapter features 5x USB-A and 2x USB-C device ports. Built with a durable all-metal enclosure, it withstands harsh and industrial environments while offering Level-4 Electrostatic Discharge (ESD) protection (15kV Air / 8kV Contact) to safeguard connected devices. For secure connections, this hub includes two 3.3ft (1m) USB cables (USB-C to C & USB-C to A) with side screw locking to prevent accidental disconnection. The hub can be surface-mounted (on or under a desk, wall-mounted) or DIN rail-mounted, ensuring a secure and space-efficient installation. This versatile hub can be powered via the included universal power adapter or the 7-24V DC terminal block, making it ideal for industrial settings or where standard power outlets may be limited. When not connected to a host, the hub functions as a dedicated charging station, supporting BC1.2 charging / Dedicated Charging Port (DCP) across all ports. Each port delivers up to 2.4A, with a total power budget of 40W (8A) when all ports are in use, ensuring efficient charging for multiple high-powered peripherals. With speeds of up to 10Gbps on all downstream ports, this hub is ideal for data storage banks, SSDs, NVMe enclosures, RAID drive enclosures, and 3D printers/scanners. It is fully backwards compatible with USB 3.2 Gen 1 (5Gbps), USB 2.0, and USB 1.x devices. This TAA Compliant hub is compatible with all operating systems and host devices and has been tested for compatibility with Windows, macOS, Linux, and ChromeOS.
Power & Charging
This versatile hub can be powered via the included universal power adapter or the 7-24V DC terminal block, making it ideal for industrial settings or where standard power outlets may be limited. When not connected to a host, the hub functions as a dedicated charging station, supporting BC1.2 charging / Dedicated Charging Port (DCP) across all ports. Each port delivers up to 2.4A, with a total power budget of 40W (8A) when all ports are in use, ensuring efficient charging for multiple high-powered peripherals. -
High-Speed Data Transfer
With speeds of up to 10Gbps on all downstream ports, this hub is ideal for data storage banks, SSDs, NVMe enclosures, RAID drive enclosures, and 3D printers/scanners. It is fully backwards compatible with USB 3.2 Gen 1 (5Gbps), USB 2.0, and USB 1.x devices. -
OS-Independent
- StarTech.com 7-Port Industrial USB Hub 10Gbps Hub, Metal, Mountable, TAA - hub - industrial - 7 ports - rack-mountable - TAA Compliant
- Hub - 7 ports
- Enclosure Type
- Rack-mountable
- Subtype
- USB
- Ports
- 7 x USB 3.2 Gen 2
- Performance
- Data transfer rate: 10 Gbps
- Steel housing, screw lock, 15KV ESD Protector (air-gap discharge), 8KV ESD Protector (contact discharge)
- USB 3.2 Gen 1, USB 3.2 Gen 2, USB 3.0, USB 2.0, USB 1.1, Battery Charging 1.2
- Power
- AC 110-240 V
- 2.6 cm x 2.6 cm x 17.8 cm
- 300 g
- Black
- Localisation
- Australia, Europe, Japan, New Zealand, North America, United Kingdom
- TAA Compliant
- 2-year warranty
- Hub - 7 ports
- Enclosure Type
- Desktop, DIN rail mountable, rack-mountable
- Subtype
- USB
- Ports
- 7 x USB 3.2 Gen 2
- Performance
- Status Indicators
- Status, power
- 5 x USB 3.2 Gen 2 Type A , 2 x USB 3.2 Gen 2 Type C , 1 x USB 3.2 Gen 2 Type C host , 1 x 2 pin terminal block
- Power Device
- External power adapter
- Voltage Required
- AC 110-240 V
- Black
- Included Accessories
- Terminal block adapter set, 2 DIN-rail mounting brackets, USB-C locking cable (1 m), USB-A to USB-C locking cable (1 m), mounting screws, 2 rack mount brackets
- Cables Included
- 1 x USB-A to USB-C cable - 1 m , 1 x USB-C to USB-C cable - 1 m
- MTBF
- 163,021.7 hours
- WEEE, RoHS, FCC
- TAA Compliant
- Localisation
- 2.6 cm
- 2.6 cm
- 17.8 cm
- 300 g
- Shipping Weight
- 1.4 kg
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95% RH (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.59 |
StarTech.com 0.5m USB 3.1 C - Micro B Cable | In Stock | £9.59 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £41.80 |
StarTech.com 3ft Side Screw Locking USB C | In Stock | £17.39 |
StarTech.com Industrial USB 10Gbps Hub
