StarTech.com Industrial Gigabit PoE Splitter 90W Ultra Power OverEthernet
Quicklinx: G3QVWS00 Mfr#: POESLT1G48V
Device Type: Other
Type: Ethernet Switch
Device Screen Size: [N/A]
Colour: Black
Hurry, only 2 left in stock!
£108.94 ex VAT
£130.72 inc VAT
Splits a PoE connection into separate data (RJ45) and DC power (terminal block) that can power any device that uses DC power between 12V-48VDC (1.5A). Power non-PoE devices using network infrastructure, where power is not available.
  • Power non-PoE devices
    Perfect for using PoE to power older devices while also providing network access for monitoring and control applications.
  • Designed for harsh environments
    Industrial features include -40°C to 75°C operating temperature, IP-30 rated housing, vibration, shock, and free-fall standard testing.
StarTech.com Industrial Gigabit PoE Splitter, 90W High Speed Power over Ethernet PoE+++ Splitter, 12-48V DC Splitter 802.3bt, LAN/RJ45 Ultra PoE to DC Adapter, -40C to +75C, High Power - Gigabit PoE Splitter (POESLT1G48V) - PoE splitter - 90 Watt
PoE splitter - DIN rail mountable
Power Over Ethernet (PoE)
PoE++
150 g
Output Voltage
12 / 16 / 24 / 48 V
Power Capacity
90 Watt
Input Connectors
1 x RJ-45
Output connectors
1 x 4 pin terminal block
Mounting kit, terminal block
8.15 cm x 10.4 cm x 3.2 cm
PoE++ (IEEE 802.3bt)
Input Connectors
1 x RJ-45
Output Voltage
12 / 16 / 24 / 48 V
Max Electric Current
1.5 A
Power Capacity
90 Watt
1 x Gigabit LAN - RJ-45
MTBF
622,154 hours
Auto MDIX support, full duplex support, rugged metal enclosure, wall mountable, auto negotiating, 6 kV ESD protection (Contract), 8 kV ESD protection (Air), LED indicators
IEEE 802.3af, IEEE 802.3at, IEEE 802.3bt, IEEE 802.3, IEEE 802.3ab, IEEE 802.3u, EN 60068-2-6, EN 60068-2-27, EN 60068-2-32, RoHS, WEEE, FCC, UL, EN 60950-1, IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, IP30
-40 °C
75 °C
5 - 95% (non-condensing)
8.15 cm
10.4 cm
3.2 cm
150 g
Shipping Width
21.1 cm
Shipping Depth
16.2 cm
Shipping Height
6.4 cm
Shipping Weight
400 g
Device Type: Other
Colour: Black
