StarTech.com Industrial Gigabit PoE Extender 60W 802.3bt PoE+
Quicklinx: G3QRWS00 Mfr#: POEEXT1G60W
Type: Extender
£132.31 ex VAT
£158.77 inc VAT
100M EXTENSION: Extend a PSE source (up to 95W) by 100m using this Gigabit PoE Extender; power PoE devices like cameras & access points; 4 extenders can be cascaded to extend up to 400m using CAT 5e/6.
60W PoE IEEE 802.3bt: Powered by the PSE source, this Power over Ethernet range extender provides up to 15W/30W/60W of auto-negotiated power output to target PD device | Low 2.7W power consumption.
TECH SPECS: 1 Gbps | 1 x RJ45 PD In | 1 x RJ45 PSE Out | IEEE 802.3af / IEEE 802.3at / IEEE 802.3bt (60W) | 10/100/1000 Mbps | 9K Jumbo Frames | DIN or Wall Mount.
ROBUST DESIGN: Industrial Power over Ethernet Network Extender w/MTBF of 500,000+hrs @ 50C | Vibration, shock & free fall rated | Rugged IP-30 aluminum housing | Hardened operating temp of -40C to 75C.
STARTECH.COM ADVANTAGE: IT professionals' choice for over 30 years | This Gigabit PoE Extender is backed for 2-years by StarTech.com, including free 24/5 North America based multi-lingual tech support.
  • Extend the reach of PoE links
    Extends the reach of PoE links to power devices over long distances. Up to 4 extenders can be cascaded to extend the range of a PoE source device.
  • Designed for harsh environments
    This PoE extender features IP30 housing for long-term reliability and durability. A wide operating temperature permits use in a wide range of indoor and outdoor applications that are not temperature controlled.
StarTech.com Industrial Single Port Gigabit PoE Extender, 60W 802.3bt PoE /PoE+/ PoE++, 100m/330ft, Power Over Ethernet Network Range Extender, IP-30 Housing, -40C to +75C, PD PoE Extender - 60W PoE++ Extender (POEEXT1G60W) - network/power extender - 10Mb LAN, 100Mb LAN, 1GbE
Network/power extender
Ports Qty
1
Cabling Type
10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate
1 Gbps
Max Transfer Distance
100 m
Power Over Ethernet (PoE)
PoE+
8.15 cm x 10.4 cm x 3.2 cm
148 g
Ports Qty
1
Wired
Cabling Type
Data Transfer Rate
1 Gbps
100 m
Status Indicators
PoE, link/activity
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), full duplex mode, rugged, Back Pressure Support, 2KV Surge protection, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), aluminium housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3bt
1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ output) - RJ-45 female , 1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ input) - RJ-45 female
Mounting Kit
Included
MTBF
551, 848 hours
IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, WEEE, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
PoE+
2.7 Watt
8.15 cm
10.4 cm
3.2 cm
148 g
Shipping Width
21.1 cm
Shipping Depth
16.2 cm
Shipping Height
6.4 cm
Shipping Weight
400 g
-40 °C
75 °C
5 - 95% (non-condensing)
Type: Extender
