StarTech.com Industrial Fiber to Ethernet Media Converter 1Gbps SFP to RJ
Quicklinx: G3QMWS00 Mfr#: IMC1GSFP
Hurry, only 2 left in stock!
£153.02 ex VAT
£183.62 inc VAT
An industrial media converter that converts fiber to copper at a network endpoint.
  • A flexible solution covering different requirements
    This media converter features an open SFP slot for any standard gigabit SFP to be used for the incoming fiber connection and is easily deployed across applications or fiber cable types. Accepts terminal block power or coaxial power connectors with the barrel plug adapter, allowing the product to be hardwired or powered using an external power supply (not included), which does not require professional installation. It can be powered using 12V-56V DC for solar, automotive, rail, and other applications and requires a minimum 12V power input. Includes hardware for DIN rail or wall mounting.
  • For mission-critical applications
    Designed with IP-30 housing and has an MBTF of >500,000 hrs (Telcordia/Bellcore) at 50°C and an operating temperature range of include -40 C to 75 C for durability; it's rated to various vibration, shock, and free-fall standards.
StarTech.com Industrial Fiber to Ethernet Media Converter, 1Gbps SFP to RJ45/ Cat6, Singlemode/Multimode Optical Fiber to Copper Gigabit Eternet Network, 12-56V DC, IP-30/ -40 to +75C - Fiber Media Converter (IMC1GSFP) - fibre media converter - 10Mb LAN, 100Mb LAN, 1GbE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
DIN rail mountable
Cabling Type
1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
8.15 cm x 10.4 cm x 3.2 cm
144 g
DIN rail mountable
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port status, active, link
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, 2KV Surge protection, 9 KB Jumbo Frame
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3x
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-SX - SFP female
Power terminal block
Mounting Kit
Included
MTBF
569,265 hours
IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
External power adapter
8.15 cm
10.4 cm
3.2 cm
144 g
Shipping Width
21.1 cm
Shipping Depth
16.2 cm
Shipping Height
6.4 cm
Shipping Weight
400 g
-40 °C
75 °C
5 - 95% (non-condensing)
Type: Fibre Media Converter
