StarTech.com Industrial 6 Pt Gigabit Ethernet Switch 5 RJ45 (4 PoE) +2 SF
Quicklinx: G3QGWS00 Mfr#: IES1G52UP12V
Type: Gigabit Ethernet
Ports: 6
Data Transfer Rate: [N/A]
Managed: [N/A]
POE: PoE+
Hurry, only 2 left in stock!
£276.47 ex VAT
£331.76 inc VAT
Easily deploy or scale your network with this Gigabit Ethernet switch, it features four dedicated PoE+ enabled ports, and one dedicated open SFP slot plus the flexibility of a switchable RJ-45/open SFP port for use as an uplink or for non-PoE devices. It features an IP-30 housing, compact design, and is wall and DIN rail mountable.
  • Power over Ethernet and low voltage
    Ideal for powering PoE devices in situations where a traditional power source is not available; it accepts power as low as 12VDC for applications such as transportation (auto/bus/rail) and solar. PoE output is boosted to PoE/PoE+ standards (IEEE 802.3af/at, 55V) in applications where non-standard 12V (or higher) power sources are available.
  • Flexible power input and low voltage
    Power input flexibility between 12/24/48/56V DC and low voltage DC inputs reduces the complexities of installation by avoiding additional in-line devices to boost power before it reaches the switch.This unique switch allows for 5x RJ-45 ports (4x PoE) to be active + 1 SFP, or 4 x RJ-45 (all PoE) + 2 SFP, for 6 device connections total.
  • Designed for harsh environments
    Industrial features include -40 C to 75 C operating temperature, IP-30 rated housing, vibration, shock, and free-fall standard testing.
  • Dual power inputs
    Dual power inputs provide redundancy. Accepts dual terminal block power, allowing the product to be hardwired from multiple power sources for high availabilty applications.
StarTech.com Industrial 6 Port Gigabit Ethernet Switch, 4 PoE RJ45 +2 SFP Slots 30W PoE+ 12-48VDC 10/100/1000 Rugged Power Over Ethernet LAN Switch -40C to 75C, DIN Mountable, Hardened - Fast Ethernet Switch (IES1G52UP12V) - switch - 6 ports
Switch - 6 ports
Subtype
Gigabit Ethernet
Ports
1 x 10/100/1000 + 4 x 10/100/1000 (PoE+) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Performance
Switching fabric speed: 12 Gbps
Jumbo Frame Support
9KB
Flow control, full duplex mode, 128KB packet buffer, rugged, 2KV ESD Protector, MDI-X
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
DC 12 - 48 V
10.5 cm x 14.2 cm x 4.3 cm
701.4 g
Switch - 6 ports
Enclosure Type
DIN rail mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Performance
Jumbo Frame Support
9KB
Status Indicators
Power, PoE, SFP, link
1 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x SFP , 1 x terminal block
DC 12 - 48 V
Terminal block connector, mounting kit
MTBF
693,764 hours
IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, UL 60950-1, EN 60950-1, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
10.5 cm
14.2 cm
4.3 cm
701.4 g
Shipping Width
21.1 cm
Shipping Depth
16.2 cm
Shipping Height
6.4 cm
Shipping Weight
900 g
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Ports: 6
Managed: [N/A]
POE: PoE+
