Easily deploy or scale your network with this Gigabit Ethernet switch, features four dedicated PoE+ enabled ports, and one dedicated open SFP slot plus the flexibility of a switchable SFP port for use as an uplink or for non-PoE devices.
                Designed for harsh environmentsIndustrial features include a wide operating temperature range, IP-30 housing, vibration, shock, and free-fall standard testing.
                Dual power inputsDual power inputs provide redundancy. Accepts terminal block power or DIN power connectors for additional power supply flexibility, allowing the product to be hardwired or powered using an external power supply, which does not require professional installation.
- StarTech.com Industrial 6 Port Gigabit Ethernet Switch 4 PoE RJ45 +2 SFP Slots 30W PoE+ 48VDC 10/100/1000 Power Over Ethernet LAN Switch -40C to 75C, DIN Connector/Mountable, Fast Ethernet - High Power PoE Switch (IES1G52UPDIN) - switch - 6 ports
- Switch - 6 ports
- Subtype
- Gigabit Ethernet
- Ports
- 1 x 10/100/1000 + 4 x 10/100/1000 (PoE+) + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 120 W
- Performance
- Switching fabric speed: 12 Gbps
- Jumbo Frame Support
- 9KB
- Flow control, full duplex mode, 1MB packet buffer, 2KV ESD Protector, MDI-X
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Power
- DC 48 - 56 V
- 10.5 cm x 14.2 cm x 3.6 cm
- 492 g
- Black
- 2-year warranty
- Switch - 6 ports
- Enclosure Type
- DIN rail mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 120 W
- Performance
- 9KB
- Status Indicators
- Power, PoE, SFP, link
- 1 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x SFP , 1 x terminal block
- Voltage Required
- DC 48 - 56 V
- 126 Watt
- Black
- Included Accessories
- Terminal block connector, mounting kit
- MTBF
- 525,058 hours
- IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, UL 60950-1, EN 60950-1, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
- 10.5 cm
- 14.2 cm
- 3.6 cm
- 492 g
- Shipping Width
- 21.1 cm
- Shipping Depth
- 16.2 cm
- Shipping Height
- 6.4 cm
- Shipping Weight
- 700 g
- Limited warranty - 2 years
- -40 °C
- 75 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 80 °C
|  | StarTech.com 4-Port PoE+/PoE++ Injector 95W | In Stock | £246.06 |
