StarTech.com Industrial 6 Port Gigabit Ethernet Switch 4 PoE RJ45 +2 SFP
Quicklinx: G3QHWS00 Mfr#: IES1G52UPDIN
Type: Gigabit Ethernet
Ports: 6
Data Transfer Rate: [N/A]
Managed: [N/A]
POE: PoE+
£190.58 ex VAT
£228.69 inc VAT
Easily deploy or scale your network with this Gigabit Ethernet switch, features four dedicated PoE+ enabled ports, and one dedicated open SFP slot plus the flexibility of a switchable SFP port for use as an uplink or for non-PoE devices.
  • Designed for harsh environments
    Industrial features include a wide operating temperature range, IP-30 housing, vibration, shock, and free-fall standard testing.
  • Dual power inputs
    Dual power inputs provide redundancy. Accepts terminal block power or DIN power connectors for additional power supply flexibility, allowing the product to be hardwired or powered using an external power supply, which does not require professional installation.
StarTech.com Industrial 6 Port Gigabit Ethernet Switch 4 PoE RJ45 +2 SFP Slots 30W PoE+ 48VDC 10/100/1000 Power Over Ethernet LAN Switch -40C to 75C, DIN Connector/Mountable, Fast Ethernet - High Power PoE Switch (IES1G52UPDIN) - switch - 6 ports
Switch - 6 ports
Subtype
Gigabit Ethernet
Ports
1 x 10/100/1000 + 4 x 10/100/1000 (PoE+) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Performance
Switching fabric speed: 12 Gbps
Jumbo Frame Support
9KB
Flow control, full duplex mode, 1MB packet buffer, 2KV ESD Protector, MDI-X
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
DC 48 - 56 V
10.5 cm x 14.2 cm x 3.6 cm
492 g
Switch - 6 ports
Enclosure Type
DIN rail mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Performance
Jumbo Frame Support
9KB
Status Indicators
Power, PoE, SFP, link
1 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x SFP , 1 x terminal block
DC 48 - 56 V
126 Watt
Terminal block connector, mounting kit
MTBF
525,058 hours
IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, UL 60950-1, EN 60950-1, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
10.5 cm
14.2 cm
3.6 cm
492 g
Shipping Width
21.1 cm
Shipping Depth
16.2 cm
Shipping Height
6.4 cm
Shipping Weight
700 g
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
80 °C
G3QH StarTech.com 4-Port PoE+/PoE++ Injector 95W In Stock £252.21
Ports: 6
Managed: [N/A]
POE: PoE+
