This industrial 5-port gigabit PoE switch (4-port PoE) features 30W of power and is designed to be installed in harsh environments and supports up to a total of 120W power outputs.
                Rugged design for harsh environmentsWith a temperature range of -40°C to 75°C and high durability, this PoE switch is built to perform reliably in tough conditions.
                High capacity for Power over EthernetThe switch supports a PoE budget of 120 W, enabling it to power various connected devices efficiently.
                Versatile networking capabilitiesFeaturing 5 ports with data rates of 10/100/1000 Mbps, the switch ensures fast and efficient data transfer for multiple applications.
                Compliant with industry standardsThis switch meets standards such as RoHS and FCC, ensuring it adheres to safety and environmental requirements.
                Flexible installation optionsThe device is designed for both DIN rail and wall mounting, allowing for easy integration into various setups.
- StarTech.com Industrial 5 Port Gigabit PoE Switch, 30W, Power Over Ethernet Switch, Hardened GbE PoE+ Unmanaged Switch, Rugged High Power Gigabit Network Switch IP-30 Housing/-40 C to 75 C - Gigabit Ethernet PoE (IESC1G50UP) - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE+) + 1 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 120 W
- Jumbo Frame Support
- 9KB
- Flow control, full duplex mode, rugged, 2KV ESD Protector, Back Pressure Support, MDI-X
- IEEE 802.3, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Power
- DC 48 - 56 V
- 8.15 cm x 10.4 cm x 3.2 cm
- 150.6 g
- Black
- 2-year warranty
- Enclosure Type
- DIN rail mountable, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 120 W
- 9KB
- Status Indicators
- Power, PoE, link
- 4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-T RJ-45 , 1 x terminal block
- Voltage Required
- DC 48 - 56 V
- 126 Watt
- Black
- Included Accessories
- Terminal block connector, mounting kit
- MTBF
- 538451 hours
- IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, UL 60950-1, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
- 8.15 cm
- 10.4 cm
- 3.2 cm
- 150.6 g
- Shipping Width
- 21.1 cm
- Shipping Depth
- 16.2 cm
- Shipping Height
- 6.4 cm
- Shipping Weight
- 392.6 g
- Limited warranty - 2 years
- -40 °C
- 75 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
|  | StarTech.com 4-Port PoE+/PoE++ Injector 95W | In Stock | £246.06 |
