This industrial 5-port gigabit PoE switch (4-port PoE) features 30W of power and is designed to be installed in harsh environments and supports up to a total of 120W power outputs.
Rugged design for harsh environments
With a temperature range of -40°C to 75°C and high durability, this PoE switch is built to perform reliably in tough conditions. -
High capacity for Power over Ethernet
The switch supports a PoE budget of 120 W, enabling it to power various connected devices efficiently. -
Versatile networking capabilities
Featuring 5 ports with data rates of 10/100/1000 Mbps, the switch ensures fast and efficient data transfer for multiple applications. -
Compliant with industry standards
This switch meets standards such as RoHS and FCC, ensuring it adheres to safety and environmental requirements. -
Flexible installation options
The device is designed for both DIN rail and wall mounting, allowing for easy integration into various setups.
- StarTech.com Industrial 5 Port Gigabit PoE Switch, 30W, Power Over Ethernet Switch, Hardened GbE PoE+ Unmanaged Switch, Rugged High Power Gigabit Network Switch IP-30 Housing/-40 C to 75 C - Gigabit Ethernet PoE (IESC1G50UP) - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE+) + 1 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 120 W
- Jumbo Frame Support
- 9KB
- Flow control, full duplex mode, rugged, 2KV ESD Protector, Back Pressure Support, MDI-X
- IEEE 802.3, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Power
- DC 48 - 56 V
- 8.15 cm x 10.4 cm x 3.2 cm
- 150.6 g
- Black
- 2-year warranty
- Enclosure Type
- DIN rail mountable, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 120 W
- 9KB
- Status Indicators
- Power, PoE, link
- 4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-T RJ-45 , 1 x terminal block
- Voltage Required
- DC 48 - 56 V
- 126 Watt
- Black
- Included Accessories
- Terminal block connector, mounting kit
- MTBF
- 538451 hours
- IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, UL 60950-1, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6
- 8.15 cm
- 10.4 cm
- 3.2 cm
- 150.6 g
- Shipping Width
- 21.1 cm
- Shipping Depth
- 16.2 cm
- Shipping Height
- 6.4 cm
- Shipping Weight
- 392.6 g
- Limited warranty - 2 years
- -40 °C
- 75 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
