Turn an Internal 3.5" SATA or IDE Hard Drive into an External USB/eSATA Hard Drive. This InfoSafe 3.5in IDE/SATA external hard drive enclosure connects to a host computer through either USB 2.0 (SATA or IDE) or eSATA (SATA only), delivering versatility and cost-effectiveness. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities.
This black aluminum drive enclosure features a screwless snap-in design for hard drive installation that saves time, and supports any standard 3.5in SATA or IDE hard drive - allowing you to customize your external storage solution based on your preference of hard drive model and manufacturer. The External hard drive enclosure features a large built-in 80mm fan that provides enhanced re-distribution of heat build-up generated as a result of typical drive operation. This feature is especially important for larger capacity hard drives, and faster "spinning" drives (i.e 7200 RPM), as it can help keep drives running cooler, which can preserve data integrity and the drive's lifespan by reducing the chances of premature failures.
Designed to provide a convenient and efficient operating experience, the enclosure features "One Touch Backup", which automates backup tasks, allowing you to backup files and folders at the touch of a button, based on pre-defined settings within the easy to use software utility (included).
- StarTech.com InfoSafe 3.5in Black eSATA USB 2.0 to IDE SATA External Hard Drive Enclosure - storage enclosure - ATA / SATA 3Gb/s - eSATA 3Gb/s, USB 2.0
- Storage enclosure - external
- Bus Type
- Black
- Localisation
- United Kingdom
- Expansion Bays
- 1 x internal - 3.5"
- Hard Drive Form Factor Compatibility
- 3.5"
- Interface
- ATA / SATA 3Gb/s
- Supported Devices
- Hard drive
- Product Material
- Aluminium
- Power Source
- Included AC adapter
- System Requirements
- Apple MacOS 9.x, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.x, Linux 2.4.1 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows 2000 / ME / XP/ Vista
- 5 cm x 21 cm x 14 cm
- 0.86 kg
- 2-year warranty
- 3.5"
- Host Bus
- Product Material
- Aluminium
- Black
- Localisation
- United Kingdom
Storage Controller
- Interface
- ATA / SATA 3Gb/s
- Supported Devices
- Hard drive
- Processor
- JMicron JM20337
- Bays
- 1 x SATA 3Gb/s - SATA , 1 x ATA - 40 PIN IDC
- Connections
- 1 x USB 2.0 - mini-USB Type B , 1 storage - eSATA-300 - 7 pin external Serial ATA
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - external , 1 x eSATA cable - external
- Tested with up to 4TB 5400 RPM hard drives
- FCC, RoHS
- Power Source
- Power adapter
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 5 cm
- 21 cm
- 14 cm
- 0.86 kg
