StarTech.com HP JL563A Comp SFP+ Copper Module - 10/100/1000/10000
Quicklinx: FJMWWS00 Mfr#: JL563A-ST
Type: Transceiver
12 In Stock
£261.43 ex VAT
£313.71 inc VAT
The JL563A-ST is a HP JL563A compatible copper transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10/100/1000/10000 compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
  • Reliable performance
    The HPE JL563A compatible module delivers robust performance with a significant mean time between failures, ensuring long-lasting reliability in various networking applications.
  • Flexible connectivity
    This module supports various Ethernet cabling types, providing flexibility for diverse networking setups, whether it is 10Base-T, 100Base-TX, 1000Base-T, or 10GBase-T.
  • High-speed transmission
    With a data transfer rate of 10 Gbps, this SFP+ transceiver module enhances data exchange speeds, making it an ideal choice for demanding networking environments.
StarTech.com HPE JL563A Compatible SFP+ Module, 10GBASE-T, SFP to RJ45 Cat6/Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, HPE 8320, 8325-48Y8, 10Gbps SFP+ Module Transceiver - Lifetime Warranty (JL563A-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - RJ-45
Plug-in module
Cabling Type
10Base-T, 100Base-TX, 1000Base-T, 10GBase-T
Data Transfer Rate
10 Gbps
10GbE
Max Transfer Distance
30 m
HP JL563A
6.8 cm x 1.37 cm x 1.38 cm
15 g
HPE Aruba 8320, 8325-48Y8C, MACsec Advanced Module; CX 10000 Empty Chassis
Plug-in module
Wired
Cabling Type
10GbE
Data Transfer Rate
10 Gbps
30 m
Full duplex mode
IEEE 802.3ae
1 x Ethernet 10GBase-T - RJ-45 female
MTBF
510,469,759 hours
FCC, MSA
HP JL563A
6.8 cm
1.37 cm
1.38 cm
15 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
HPE Aruba 8320, 8325-48Y8C, MACsec Advanced Module , HPE Aruba CX 10000 Empty Chassis
Type: Transceiver
