StarTech.com HP JG325B Compatible QSFP+ MM Module - 40GBase-SR4
Quicklinx: FHJTWS00 Mfr#: JG325B-ST
The JG325B-ST is an HP JG325Bcompatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 150 m (492 ft).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE JG325B Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multi Mode Fiber Optic Transceiver, 40GE Gigabit Ethernet QSFP+, MPO Connector, 150m, 850nm, DDM, HPE 4200, FlexFabric - Lifetime Warranty (JG325B-ST) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
Max Transfer Distance
150 m
HP JG325B
12.2 cm x 1.86 cm x 0.85 cm
37.5 g
HPE Apollo 4200 Qumulo Archive Node, 4200 Qumulo Hybrid Node, 4200 Qumulo Node; FlexFabric 12900E, 12900E 36-Port 100GbE QSFP28 Type X Module, 12900E 36-Port 40GbE QSFP+ Type X Module, 12902E Switch Chassis
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
150 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
95,832,027 hours
MSA
HP JG325B
12.2 cm
1.86 cm
0.85 cm
37.5 g
Shipping Width
12 cm
Shipping Depth
20.5 cm
Shipping Height
3.5 cm
Shipping Weight
60 g
Limited warranty - lifetime
HPE Apollo 4200 Qumulo Archive Node, 4200 Qumulo Hybrid Node, 4200 Qumulo Node , HPE FlexFabric 12900E, 12900E 36-Port 100GbE QSFP28 Type X Module, 12900E 36-Port 40GbE QSFP+ Type X Module, 12902E Switch Chassis
