StarTech.com HP JD119B Compatible SFP SM
Quicklinx: CRGHWS00 Mfr#: JD119BST
Type: Modules
£36.10 ex VAT
£43.32 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over single-mode fiber with this SFP module. This HP compatible Gigabit fiber SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into HP networking devices that support the HP JD119B transceiver module, as well as other major brands of networking equipment.
This 1000Base-LX SFP transceiver module delivers Gigabit connectivity over single-mode fiber cable, with a range of up to 10 km (6.2 mi.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This single-mode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The SM Gigabit SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP JD119B SFP transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers, and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports single-mode fiber cable with a maximum distance of 10 km or 6.2 mi., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM / DOM).
  • Reliable connectivity
    This mini-GBIC transceiver module ensures stable connections with its LC single-mode connector designed for wired environments.
  • Durable operating range
    Capable of functioning between 0°C and 70°C, this module is suitable for a wide variety of installation settings.
  • Advanced monitoring
    With Digital Optical Monitoring (DOM) and Digital Diagnostics Monitoring (DDM), users have access to critical performance data for ongoing maintenance.
  • Standards compliant
    Meets various compliance standards including UL, FCC, RoHS, and MSA, ensuring quality and safety in design.
  • Efficient data handling
    Supports Gigabit Ethernet with full duplex capabilities for optimized data flow in networking applications.
Startech HPE JD119B Compatible SFP Module, 1000BASE-LX, 1GbE Single Mode (SMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, DDM, HPE 5900, 12500, 5500 - Lifetime Warranty (JD119BST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
HP JD119B
1.37 cm x 5.66 cm x 1.25 cm
28 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-LX - LC single-mode female
UL, FCC, RoHS, MSA
HP JD119B
1.37 cm
5.66 cm
1.25 cm
28 g
Limited warranty - lifetime
70 °C
5 - 95%
CRGH StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £21.31
CRGH StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.13
CRGH StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.13
CRGH StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.44
CRGH StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £142.63
CRGH StarTech.com Fiber Media Converter - Open In Stock £43.33
CRGH StarTech.com HP JD118B Compatible SFP MM In Stock £33.14
CRGH StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £328.89
Type: Modules
