The J9151E-ST is a HP J9151E compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
Reliable performance
This SFP+ transceiver module is designed for wired connectivity with a data transfer rate of 10 Gbps, ensuring performance in demanding network environments. -
Long-distance capability
It supports a maximum transfer distance of 10 km, allowing for flexible network designs and installations without compromising on performance. -
Advanced monitoring
Featuring Digital Diagnostics Monitoring (DDM), users can access real-time information about the optical signal, helping to ensure operational efficiency. -
Energy-efficient operation
With a power consumption of only 1.3 watts during operation, this module is designed to be efficient, contributing to lower energy costs without sacrificing performance. -
Robust design
With an MTBF of over 1.3 billion hours, this module is built to last, providing reliability in various networking applications.
 - StarTech.com HPE J9151E Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 10km, 1310nm, DDM, HPE 2930F, 8325, 3810M - Lifetime Warranty (J9151E-ST) - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC single-mode
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-LR
- Data Transfer Rate
 - 10 Gbps
- Optical Wave Length
 - 1310 nm
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 10 km
- OEM Manufacturer Equivalent Part Number
 - HP J9151E
 - 5.84 cm x 1.39 cm x 1.37 cm
 - 21 g
 - Limited lifetime warranty
- Designed For
 - HPE Aruba 2540 24, 2540 48, 2930F 12, 2930F 24, 2930F 48, 2930F 8G, 2930M 24, 2930M 40, 2930M 48, 3810M 16, 3810M 24, 3810M 40, 3810M 48, 5406R 16, 5406R 44, 5406R 8-port, 5406R zl2, 5412R 92, 5412R zl2, 54XX, 6200F 12, 6200M 24, 6300, 6405 48, 6405 96, 64XX, 83XX, 8400 8-slot; CX 8360
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-LR
 - 10GbE
 - 10 Gbps
 - 1310 nm
 - 10 km
 - Digital Diagnostics Monitoring (DDM), full duplex mode
 - 1 x Ethernet 10GBase-LR - LC single-mode female x 2
- MTBF
 - 1,386,624,697 hours
 - MSA
 - HP J9151E
 - 1.3 Watt
 - 5.84 cm
 - 1.39 cm
 - 1.37 cm
 - 21 g
- Shipping Width
 - 9 cm
- Shipping Depth
 - 11.5 cm
- Shipping Height
 - 3.1 cm
- Shipping Weight
 - 50 g
 - Limited warranty - lifetime
- Designed For
 - HPE Aruba 2540 24G 4SFP+, 2540 24G PoE+ 4SFP+, 2540 48G 4SFP+, 2540 48G PoE+ 4SFP+, 2930F 12G PoE+ 2G/2SFP+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 24G PoE+ 4SFP+ TAA, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 2930F 48G PoE+ 4SFP+ TAA, 2930F 8G PoE+ 2SFP+, 2930F 8G PoE+ 2SFP+ TAA, 2930M 24 Smart Rate POE+ 1-Slot, 2930M 24G 1-Slot, 2930M 24G POE+ 1-Slot, 2930M 40G 8 HPE Smart Rate PoE Class 6 1-slot Switch, 2930M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 2930M 48G 1-Slot, 2930M 48G POE+ 1-Slot, 3810M 16SFP+ 2-slot Switch, 3810M 24G 1-slot Switch, 3810M 24G PoE+ 1-slot Switch, 3810M 24SFP+ 250W, 3810M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 3810M 48G 1-slot Switch, 3810M 48G PoE+ 1-slot Switch, 3810M 48G PoE+ 4SFP+ 1050W, 3810M 48G PoE+ 4SFP+ 680W, 5406R 16-port SFP+ (No PSU) v3 zl2, 5406R 44GT PoE+ / 4SFP+ (No PSU) v3 zl2, 5406R 8-port 1/2.5/5/10GBASE-T PoE+ / 8-port SFP+ (No PSU) v3 zl2, 5406R zl2, 5406R-44G-PoE+/2SFP+ v2 zl2, 5406R-44G-PoE+/4SFP v2 zl2, 5406R-8XGT/8SFP+ v2 zl2, 5412R 92GT PoE+ / 4SFP+ (No PSU) v3 zl2, 5412R zl2, 5412R-92G-PoE+/2SFP+ (No PSU) v2 zl2, 5412R-92G-PoE+/2SFP+ v2 zl2, 5412R-92G-PoE+/4SFP v2 zl2, 6200F 12G Class4 PoE 2G/2SFP+ 139W Switch, 6200F 12G Class4 PoE 2G/2SFP+ 139W TAA Switch, 6200M 24G Class4 PoE 4SFP+, 6300F, 6300M, 6405 48SFP+ 8SFP56, 6405 96G CL4 PoE 4SFP56, 6405 Switch Bundle, 6410, 6410 Switch Bundle, 8320, 8325-32C, 8325-48Y8C, 8400 8-slot Chassis , HPE Aruba CX 8360-12C V2, 8360-16Y2C V2, 8360-48XT4C v2
