StarTech.com HP J9150D Compatible SFP+ MM Module - 10GBase-SR
Quicklinx: FHJ7WS00 Mfr#: J9150D-ST
Type: Modules
15 In Stock
£117.58 ex VAT
£141.09 inc VAT
The J9150D-ST is a HP J9150D compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 300 m (984 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
  • Reliable connectivity
    Designed for wired networks, the HPE J9150D Compatible SFP+ Module provides a consistent and high-performance connectivity option for 10 Gigabit Ethernet, ensuring data transmission remains smooth and efficient.
  • Efficient power usage
    With an operational power consumption of 1.3 watts, this module offers energy efficiency, helping to lower operational costs while maintaining robust network performance.
  • Versatile compatibility
    This SFP+ transceiver module complies with MSA standards, making it compatible with a wide variety of networking equipment for greater flexibility and functionality.
  • Enhanced operational longevity
    An MTBF of 498,745,585 hours indicates the module’s reliability and the low likelihood of unexpected service interruptions, reinforcing its suitability for critical network applications.
  • Effective range
    The optical wave length of 850 nm allows the module to effectively transmit data over a distance of 300 m, catering to medium-reach networking needs without compromise on speed or reliability.
StarTech.com HPE J9150D Compatible SFP+ Module, 10GBASE-SR, 10GbE Multi Mode Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 300m, 850nm, DDM, HPE FlexFabric, 6120XG, 6120G - Lifetime Warranty (J9150D-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
HP J9150D
5.84 cm x 1.39 cm x 1.37 cm
20 g
HPE Aruba 2540 24, 2540 48, 2930F 12, 2930F 24, 2930F 48, 2930F 8G, 2930M 24, 2930M 40, 2930M 48, 3810M 24, 3810M 40, 3810M 48, 5406R 16, 5406R 44, 5406R 8-port, 5406R zl2, 5412R 92, 5412R zl2, 54XX, 6200F 12, 6200M 24, 6300, 6405 48, 6405 96, 64XX, 70XX, 72XX, 83XX, 8400, 8400 8-slot; CX 8360
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Digital Diagnostics Monitoring (DDM), full duplex mode
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MTBF
498,745,585 hours
MSA
HP J9150D
1.3 Watt
5.84 cm
1.39 cm
1.37 cm
20 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
HPE Aruba 2930F 12G PoE+ 2G/2SFP+, 2930F 8G PoE+ 2SFP+ TAA, 2930M 24 Smart Rate POE+ 1-Slot, 2930M 24G 1-Slot, 2930M 24G POE+ 1-Slot, 2930M 40G 8 HPE Smart Rate PoE Class 6 1-slot Switch, 2930M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 2930M 48G 1-Slot, 2930M 48G POE+ 1-Slot, 3810M 24SFP+ 250W, 3810M 48G PoE+ 4SFP+ 1050W, 3810M 48G PoE+ 4SFP+ 680W, 6200F 12G Class4 PoE 2G/2SFP+ 139W Switch, 6200F 12G Class4 PoE 2G/2SFP+ 139W TAA Switch, 6200M 24G Class4 PoE 4SFP+, 6300F, 6300M, 6405 48SFP+ 8SFP56, 6405 96G CL4 PoE 4SFP56, 6405 Switch Bundle, 6410, 6410 Switch Bundle, 7005 (IL) FIPS/TAA-compliant Controller, 7005 (JP) Controller, 7005 (JP) FIPS/TAA Controller, 7005 (RW) FIPS/TAA-compliant Controller, 7005 (US) FIPS/TAA Controller, 7005 Cloud Service Controller, 7010 (IL) Controller, 7010 (JP) FIPS/TAA Controller, 7010 (RW) FIPS/TAA-compliant Controller, 7024 (JP) FIPS/TAA Controller, 7024 (RW) FIPS/TAA-compliant Controller, 7024 (US) Controller, 7024 (US) FIPS/TAA Controller, 7030 (JP) FIPS/TAA Controller, 7030 (RW) FIPS/TAA-compliant Controller, 7030 (US), 7030 (US) Controller, 7030 (US) FIPS/TAA Controller, 7205 (IL) FIPS/TAA-compliant Controller, 7205 (JP) Controller, 7205 (JP) FIPS/TAA Controller, 7205 (RW) FIPS/TAA-compliant Controller, 7205 (US), 7205 (US) Controller, 7205 (US) FIPS/TAA Controller, 7210 (JP) FIPS/TAA Controller, 7210 (RW) FIPS/TAA-compliant Controller, 7210 (US), 7210 (US) FIPS/TAA Controller, 7210DC (JP) Controller, 7210DC (US) Controller, 7220 (JP) Controller, 7220 (RW) FIPS/TAA-compliant Controller, 7220 (US) FIPS/TAA Controller, 7220DC (IL) Mobility Controller, 7220DC (US) Controller, 7240 (RW) FIPS/TAA-compliant Controller, 7240 (US) FIPS/TAA Controller, 7240XM (IL) FIPS Controller, 7240XM (JP) FIPS/TAA Controller, 7240XM (RW) FIPS Controller, 7240XM (US) FIPS Controller, 8320, 8325-32C, 8325-48Y8C, 8400 8-slot Chassis, 8400 Management Module , HPE Aruba CX 8360-12C V2, 8360-16Y2C V2
Type: Modules
