StarTech.com HP Compliant 10GBase-T SFP+ Transceiver Module
Quicklinx: DZ78WS00 Mfr#: 813874B21ST
Type: Transceiver
£153.01 ex VAT
£183.61 inc VAT
The 813874B21ST is an HP 813874-B21 compatible copper transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10GBASE-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This SFP+ copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HP 813874-B21 Compatible SFP+ Module - 10GBASE-T RJ45 Copper Transceiver - 813874B21ST - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - RJ-45
Plug-in module
Cabling Type
10GBase-T
Data Transfer Rate
10 Gbps
10 GigE
Max Transfer Distance
30 m
HP 813874-B21
1.34 cm x 6.98 cm x 1.38 cm
24.2 g
Plug-in module
Silver
Wired
Cabling Type
10GBase-T
10 GigE
Data Transfer Rate
10 Gbps
30 m
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3an
1 x Ethernet 10GBase-T - RJ-45
MTBF
4,598,430 hours
MSA
HP 813874-B21
2.3 Watt
1.34 cm
6.98 cm
1.38 cm
24.2 g
Limited warranty - lifetime
70 °C
Type: Transceiver
Price Range Ex VAT: 150 - 300
