StarTech.com HP Compliant 10GBase-T SFP+ Transceiver Module
Quicklinx: DZ78WS00 Mfr#: 813874B21ST
Type: Transceiver
£163.20 ex VAT
£195.84 inc VAT
The 813874B21ST is an HP 813874-B21 compatible copper transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10GBASE-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This SFP+ copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
  • StarTech.com SFPs
    All StarTech.com SFP & SFP+ transceiver modules are backed by a lifetime warranty and free lifetime multilingual technical support. StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE 813874-B21 Compatible SFP+ Module, 10GBASE-T, SFP to RJ45 Cat6/Cat5e, 10GE Gigabit Ethernet SFP+, RJ-45 (Copper) 30m, HPE BladeSystem, c-Class, Mini GBIC SFP+ Transceiver - Lifetime Warranty (813874B21ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - RJ-45
Plug-in module
Cabling Type
10GBase-T
Data Transfer Rate
10 Gbps
10GbE
Max Transfer Distance
30 m
HP 813874-B21
1.34 cm x 6.98 cm x 1.38 cm
24.2 g
Plug-in module
Silver
Wired
Cabling Type
10GBase-T
10GbE
Data Transfer Rate
10 Gbps
30 m
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3an
1 x Ethernet 10GBase-T - RJ-45
MTBF
4,598,430 hours
MSA
HP 813874-B21
2.3 Watt
1.34 cm
6.98 cm
1.38 cm
24.2 g
Limited warranty - lifetime
70 °C
Type: Transceiver
