StarTech.com HP Compatible RJ45 SFP 10 Pack
Quicklinx: C57ZWS00 Mfr#: J8177C10PKST
£248.97 ex VAT
£298.76 inc VAT
Ensure reliable Gigabit Ethernet connections and maximum cost-savings with this bulk pack of RJ45 Mini-GBIC modules. Ideal for large-scale deployments or installations on multiple devices, this bulk pack of HP compatible Gigabit fiber SFPs is engineered by StarTech.com to deliver reliability and maximum cost savings. Built to exacting specifications and fully tested to ensure maximum performance, you can install these high-quality transceiver modules into HP networking devices that support the J8177C transceiver module, as well as other major brands of networking equipment.
These 1000Base-T SFPs deliver Gigabit connectivity over copper cable with a maximum distance of 100 m (328 ft.). The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the copper Ethernet ports on your networking equipment.
The SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit RJ45 SFPs are engineered to the highest quality standards and are 100% HP compatible, equivalent to the HP J8177C mini-GBIC. StarTech.com transceivers are configured and fully tested to ensure they work seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these SFP transceiver modules are fully hot-pluggable, which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a convenient solution that's compatible with a wide range of multi- and single-port Gigabit Ethernet networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost effectively. The SFPs support autonegotiation, a maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
StarTech.com 10 Pack of HPE J8177C Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, HPE 1810, 1820, 2530, Mini GBIC Transceiver - Lifetime Warranty (J8177C10PKST) - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45 / SFP (mini-GBIC)
Packaged Quantity
10 (specifications are for single item)
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
GigE
Max Transfer Distance
100 m
HP J8177C
1.4 cm x 6.8 cm x 1.4 cm
25 g
HP Switch 2610-24, Switch 2610-24/12, Switch 2610-48; HPE 1810, 1910, 20p 10/100/1000, 2610, 3500, 6200, Switch 53XX, Switch 5406, Switch 8212, Switch gl 10/100/1000, Switch gl Mini-GBIC Module, Switch vl 4-port, Switch xl Mini-GBIC Module, vl 20; HPE Aruba 2530, 5406, Switch 5400zl 24
Packaged Quantity
Plug-in module
Silver
Wired
Cabling Type
1000Base-T
GigE
Data Transfer Rate
1 Gbps
100 m
Auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 female
FCC, RoHS, MSA
HP J8177C
1.4 cm
6.8 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
30 - 75%
HP Switch 2610-24, Switch 2610-24/12-PWR, Switch 2610-24-PWR, Switch 2610-48, Switch 2610-48-PWR, Switch 5406zl-48G Intelligent Edge, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge , HPE 1810-24 v2, 1810-8 v2, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 20p 10/100/1000 + 4p Mini-GBIC Module, 2610-24 Switch, 2610-24-PoE Switch, 2610-24-PPoE Switch, 2610-48 Switch, 2610-48-PoE Switch, 3500-24G-PoE yl Switch, 3500-48G-PoE yl Switch, 6200-24G-mGBIC yl Switch, Switch 5348xl, Switch 5372xl, Switch 5406zl Intelligent Edge, Switch 8212zl, Switch gl 10/100/1000 Module, Switch gl Mini-GBIC Module, Switch vl 4-port Mini-GBIC Module, Switch xl Mini-GBIC Module, vl 20p Gig-T+ 4P SFP module switch , HPE Aruba 2530-24G, 2530-24G-PoE+, 2530-48G, 2530-48G-PoE+, 2530-48-PoE+, 5406 zl, Switch 5400zl 24p Mini-GBIC Module
C57Z StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £24.33
C57Z StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £129.72
C57Z StarTech.com 10 Pt Gigabit Ethernet Switch In Stock £116.51
C57Z StarTech.com Fiber Media Converter - Open In Stock £62.11
C57Z StarTech.com SFP - HP J4858C Comp. 10 Pack In Stock £236.49
C57Z StarTech.com SFP - HP J4859C Comp. 10 Pack In Stock £272.58
C57Z StarTech.com HP Compatible RJ45 SFP 10 Pack In Stock £248.97
C57Z StarTech.com Gb RJ45 SFP - HP Compatible In Stock £36.98
C57Z StarTech.com SFP+ - HP J9151A Compatible In Stock £157.13
C57Z StarTech.com SFP+ - HP JD092B Compatible In Stock £124.48
C57Z StarTech.com SFP+ - HP J9150A Compatible In Stock £210.96
C57Z StarTech.com SFP - HP J4859C Compatible In Stock £41.16
C57Z StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £299.31
Stock Status: In stock
