StarTech.com HP 455886-B21 Compatible SFP+ SM Module - 10GBase-LR
Quicklinx: FHH3WS00 Mfr#: 455886-B21-ST
Hurry, only 2 left in stock!
£53.70 ex VAT
£64.44 inc VAT
The 455886-B21-ST is a HP 455886-B21 compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com HPE 455886-B21 Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber Optic Transceiver, LC 10km, 1310nm DDM, HPE BladeSystem 562SFP+ 560SFP+, Mini GBIC Transceiver - Lifetime Warranty (455886-B21-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
10 km
HP 455886-B21
5.84 cm x 1.39 cm x 1.37 cm
21 g
HPE SimpliVity 380 Gen10 Node, 380 Gen9 Node; Virtual Connect Flex-10
Plug-in module
Wired
Cabling Type
10GBase-LR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MTBF
1,386,624,697 hours
MSA
HP 455886-B21
1.3 Watt
5.84 cm
1.39 cm
1.37 cm
21 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
HPE SimpliVity 380 Gen10 Node, 380 Gen9 Node , HPE Virtual Connect Flex-10
