StarTech.com HP 3CSFP91 Compatible SFP Module
Quicklinx: CRFQWS00 Mfr#: 3CSFP91ST
Type: Modules
Hurry, only 1 left in stock!
£22.14 ex VAT
£26.56 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over multimode fiber with this SFP module. This Gigabit fiber SFP is HP compatible and engineered by StarTech.com to deliver what you need most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP switches and routers that support the HP 3CSFP91 transceiver module, as well as other major brands of networking equipment.
This 1000Base-SX SFP delivers Gigabit connectivity over multimode fiber cable, with a range of up to 550 m (1804 ft.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This multimode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The MM Gigabit SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP 3CSFP91 transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers, and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports multimode fiber cable with a maximum distance of 550 m or 1804 ft., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM / DOM).
StarTech.com HPE 3CSFP91 Compatible SFP Module, 1000BASE-SX, 1GbE Multi Mode (MMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, HPE 3812, 3824, 3848 - Lifetime Warranty (3CSFP91ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
HP 3CSFP91
1.37 cm x 5.66 cm x 1.25 cm
28 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
UL, FCC, RoHS, MSA
HP 3CSFP91
1.37 cm
5.66 cm
1.25 cm
28 g
Limited warranty - lifetime
70 °C
5 - 95%
CRFQ StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £13.98
CRFQ StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £23.49
CRFQ StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.11
CRFQ StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £19.13
CRFQ StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.60
CRFQ StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £139.16
CRFQ StarTech.com Fiber Media Converter - Open In Stock £42.26
CRFQ StarTech.com HP 3CSFP91 Compatible SFP Module In Stock £22.14
CRFQ StarTech.com HP JD118B Compatible SFP MM In Stock £32.84
CRFQ StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £320.87
Type: Modules
