The 0231A0A8-ST is a HP 0231A0A8 compatible fiber transceiver module that has been designed, programmed and tested to work with HP brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
 - StarTech.com HP 0231A0A8 Compatible SFP+ Module - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC single-mode
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-LR
- Data Transfer Rate
 - 10 Gbps
- Optical Wave Length
 - 1310 nm
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 10 km
- OEM Manufacturer Equivalent Part Number
 - HP 0231A0A8
 - 5.84 cm x 1.39 cm x 1.37 cm
 - 21 g
 - Limited lifetime warranty
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-LR
 - 10GbE
 - 10 Gbps
 - 1310 nm
 - 10 km
 - Full duplex mode, Digital Diagnostics Monitoring (DDM)
 - 1 x Ethernet 10GBase-LR - LC single-mode female x 2
- MTBF
 - 1,386,624,697 hours
 - FCC, MSA
 - HP 0231A0A8
 - 1.3 Watt
 - 5.84 cm
 - 1.39 cm
 - 1.37 cm
 - 21 g
- Shipping Width
 - 9 cm
- Shipping Depth
 - 11.5 cm
- Shipping Height
 - 3.1 cm
- Shipping Weight
 - 50 g
 - Limited warranty - lifetime
