The 30 cm (1 ft) High Speed HDMI Cable from StarTech.com is designed to support the spectrum of high-definition and ultra-high-definition resolutions. With its shielded construction, this cable minimizes interference while delivering 4K at 60 Hz performance. The combination of 18 Gbps data rate, 12-bit Deep Color, and 7.1 channel Surround Sound ensures an immersive experience whether connected to a monitor, TV, or display. Equipped with features such as HDMI Ethernet Channel (HEC) and Audio Return Channel (ARC), this HDMI cable enhances connectivity options while supporting a variety of audio formats. The durable gold-plated connectors provide reliable performance and resist wear over time, making it suitable for demanding setups. With a lifespan of up to 10,000 insertions and 2,000 bends, this cable is built to last while offering flexibility for a neat and organized installation.
Robust shielding technology
The cable features shielded construction with aluminum mylar foil and braid to reduce interference, ensuring stable signal transmission. -
High-performance specifications
Supports a data rate of 18 Gbps while accommodating 4K 60 Hz resolutions, 12-bit Deep Color, and a 21:9 cinema aspect ratio for high-quality visuals. -
Versatile audio support
Offers 7.1 channel Surround Sound and support for up to 32 audio channels, enhancing the audio experience for immersive sound environments. -
Durable and reliable design
Built to withstand a lifespan of 10,000 insertions and 2,000 bends, providing long-term reliability for active setups. -
Eco-conscious materials
Constructed from halogen-free materials and compliant with RoHS and WEEE standards, making it an environmentally responsible choice.
- StarTech.com 30cm (1ft) High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 30 cm
- Cable
- Premium High Speed - HDMI cable with Ethernet
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 30 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive cable
- Limited lifetime warranty
- Cable Type
- Premium High Speed - HDMI cable with Ethernet 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive
- Technology
- Shielded
- 30
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 30 cm
- Plated Connector
- Gold
- Recommended Use
- Display, monitor, TV
- HDR 10 support, 18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), 2000 bend lifespan, 10000 insertions lifespan, strain relief, 21:9 cinema aspect ratio, 32 audio channels, 12 Bit Deep Colour, 7.1 channel Surround Sound, EMI protection, outer diameter 6mm
- Black
- Connector
- 19 pin HDMI Type A - male
- HDCP 2.2, WEEE, RoHS
- 40 g
- Shipping Width
- 12.5 cm
- Shipping Depth
- 9 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 45 g
- Limited warranty - lifetime
