StarTech.com High Speed HDMI Cable 30cm
Quicklinx: J1MGWS00 Mfr#: HDMI2-CABLE-4K60-30C
Length: 30cm
More than 50 In Stock
£4.67 ex VAT
£5.60 inc VAT
The 30 cm (1 ft) High Speed HDMI Cable from StarTech.com is designed to support the spectrum of high-definition and ultra-high-definition resolutions. With its shielded construction, this cable minimizes interference while delivering 4K at 60 Hz performance. The combination of 18 Gbps data rate, 12-bit Deep Color, and 7.1 channel Surround Sound ensures an immersive experience whether connected to a monitor, TV, or display. Equipped with features such as HDMI Ethernet Channel (HEC) and Audio Return Channel (ARC), this HDMI cable enhances connectivity options while supporting a variety of audio formats. The durable gold-plated connectors provide reliable performance and resist wear over time, making it suitable for demanding setups. With a lifespan of up to 10,000 insertions and 2,000 bends, this cable is built to last while offering flexibility for a neat and organized installation.
  • Robust shielding technology
    The cable features shielded construction with aluminum mylar foil and braid to reduce interference, ensuring stable signal transmission.
  • High-performance specifications
    Supports a data rate of 18 Gbps while accommodating 4K 60 Hz resolutions, 12-bit Deep Color, and a 21:9 cinema aspect ratio for high-quality visuals.
  • Versatile audio support
    Offers 7.1 channel Surround Sound and support for up to 32 audio channels, enhancing the audio experience for immersive sound environments.
  • Durable and reliable design
    Built to withstand a lifespan of 10,000 insertions and 2,000 bends, providing long-term reliability for active setups.
  • Eco-conscious materials
    Constructed from halogen-free materials and compliant with RoHS and WEEE standards, making it an environmentally responsible choice.
StarTech.com 30cm (1ft) High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 30 cm
Cable
Premium High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
30
Length
30 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, 2K144Hz support, 1080p support 240Hz, halogen-free, passive
Shielded
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
30 cm
Plated Connector
Gold
Recommended Use
Display, monitor, TV
HDR 10 support, 18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), 2000 bend lifespan, 10000 insertions lifespan, strain relief, 21:9 cinema aspect ratio, 32 audio channels, 12 Bit Deep Colour, 7.1 channel Surround Sound, EMI protection, outer diameter 6mm
Connector
19 pin HDMI Type A - male
HDCP 2.2, WEEE, RoHS
40 g
Shipping Width
12.5 cm
Shipping Depth
9 cm
Shipping Height
1 cm
Shipping Weight
45 g
Limited warranty - lifetime
Length: 30cm
