Convert a DVI-D (Digital) signal to work with a VGA monitor. The DVI2VGACON high resolution video DVI to VGA converter converts a DVI-D (digital) input video signal to a VGA (analog) output, saving time and money by eliminating the need to purchase a new digital display for compatibility with DVI-D video cards or devices.
This compact adapter provides support for resolutions up to 1920x1200, allowing you to take full advantage of your VGA monitor's capabilities. A true plug-and-play solution, the DVI-D to VGA adapter is easy to install; simply connect the DVI-D output port to the adapter using the included DVI cable, then connect a VGA monitor/projector to the VGA port on the adapter.
- StarTech.com High Resolution Video DVI to VGA Converter - Video converter - DVI - VGA - black - DVI2VGACON - video converter - black
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 1920 x 1200
- 1 x DVI-D input - 24+1 pin digital DVI , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable) , 1 x USB (power only) - 4 pin USB Type A (on supplied cable) , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- 4.8 cm x 8.8 cm x 2.4 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DVI-D input - 24+1 pin digital DVI - female , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable) - male , 1 x USB (power only) - 4 pin USB Type A (on supplied cable) - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
- LED indicator, USB powered
- Cables Included
- 1 x DVI cable - 30.5 cm , 1 x USB power cable
- FCC, RoHS
- 4.8 cm
- 8.8 cm
- 2.4 cm
- 61 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable | In Stock | £5.05 |
StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 | In Stock | £22.78 |
