StarTech.com High Resolution Video DVI to VGA Converter
Quicklinx: 76RYWS00 Mfr#: DVI2VGACON
Type: DVI
Hurry, only 1 left in stock!
£88.71 ex VAT
£106.45 inc VAT
Convert a DVI-D (Digital) signal to work with a VGA monitor. The DVI2VGACON high resolution video DVI to VGA converter converts a DVI-D (digital) input video signal to a VGA (analog) output, saving time and money by eliminating the need to purchase a new digital display for compatibility with DVI-D video cards or devices.
This compact adapter provides support for resolutions up to 1920x1200, allowing you to take full advantage of your VGA monitor's capabilities. A true plug-and-play solution, the DVI-D to VGA adapter is easy to install; simply connect the DVI-D output port to the adapter using the included DVI cable, then connect a VGA monitor/projector to the VGA port on the adapter.
StarTech.com High Resolution Video DVI to VGA Converter - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DVI-D input - 24+1 pin digital DVI , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable) , 1 x USB (power only) - 4 pin USB Type A (on supplied cable) , 1 x VGA output - 15 pin HD D-Sub (HD-15)
4.8 cm x 8.8 cm x 2.4 cm
Enclosure Colour
Video converter
Max Resolution
1920 x 1200
1 x DVI-D input - 24+1 pin digital DVI - female , 1 x DVI-D input - 24+1 pin digital DVI (on supplied cable) - male , 1 x USB (power only) - 4 pin USB Type A (on supplied cable) - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
LED indicator, USB powered
1 x DVI cable - 30.5 cm , 1 x USB power cable
FCC, RoHS
4.8 cm
8.8 cm
2.4 cm
61 g
Enclosure Colour
0 - 80%
76RY StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
76RY StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
76RY StarTech.com High Resolution Video DVI to VGA Converter In Stock £88.71
76RY StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £22.86
Type: DVI
Price Range Ex VAT: 50 - 100
