The ARMPIVOT Adjustable Monitor Arm lets you mount a display to your desk or table on a simple yet stylish monitor pole, with tilt, pivot and height adjustments.
The desk-mount monitor arm features an 11.89in (302mm) tall support post, for a much greater height adjustment range than a typical monitor stand can provide. For viewing longer pages or blocks of code without scrolling, the LCD arm also supports landscape to portrait display rotation.
Mounting your displays on a support post above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 30" displays up to a maximum weight capacity of 30lbs (14kg), the monitor mount holds your display with ease, and integrates a cable management hook to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk, table or mount through a grommet hole.
- StarTech.com Desk Mount Monitor Arm - Full Motion Articulating - Monitors 12" to 34" Adjustable VESA Single Monitor Arm - Desk & Grommet Clamp - Black (ARMPIVOTE) mounting kit - for LCD display - black
- Product Type
- Mounting kit - desktop
- Mounting Components
- Articulating arm
- Adjustments
- Pan, tilt
- Recommended Use
- LCD display
- Recommended Display Size
- 12"-24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 5 kg
- Material
- Plastic, steel
- Black
- 2-year warranty
- Designed For
- P/N: ACCSMNT, ARMSTS, STSCART
- Material
- Plastic, steel
- Black
AV Furniture
- Mounting kit
- Articulating arm
- Recommended Use
- LCD display
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- 12"-24"
- Adjustments
- Pan, tilt
- Max Load Weight
- 5 kg
- Adjustable height, portrait to landscape movement, swivel adjustment, gas-spring technology, pivot
- Limited warranty - 2 years
- Designed For
StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook | In Stock | £64.93 |
StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit | In Stock | £87.94 |
StarTech.com Articulating Monitor Arm | In Stock | £121.96 |
StarTech.com Sit-to-Stand Workstation | In Stock | £121.36 |
StarTech.com Monitor and Laptop Arm | In Stock | £114.13 |
StarTech.com USB-C Multifunction Adapter | In Stock | £46.69 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £70.33 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.67 |
StarTech.com Under Desk Keyboard Tray | In Stock | £53.36 |
StarTech.com Single Monitor Stand | In Stock | £53.87 |
