StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook
Quicklinx: 9XDBWS00 Mfr#: ARMPIVOT
Accessory Type: Bracket
£56.06 ex VAT
£67.27 inc VAT
The ARMPIVOT Adjustable Monitor Arm lets you mount a display to your desk or table on a simple yet stylish monitor pole, with tilt, pivot and height adjustments.
The desk-mount monitor arm features an 11.89in (302mm) tall support post, for a much greater height adjustment range than a typical monitor stand can provide. For viewing longer pages or blocks of code without scrolling, the LCD arm also supports landscape to portrait display rotation.
Mounting your displays on a support post above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 30" displays up to a maximum weight capacity of 30lbs (14kg), the monitor mount holds your display with ease, and integrates a cable management hook to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk, table or mount through a grommet hole.
StarTech.com Desk Mount Monitor Arm - Full Motion Articulating - Monitors 12" to 34" Adjustable VESA Single Monitor Arm - Desk & Grommet Clamp - Black (ARMPIVOTE) - mounting kit
Mounting kit - desktop
Mounting Components
Articulating arm
Adjustments
Pan, tilt
Recommended Use
LCD display
Recommended Display Size
12"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
Material
Plastic, steel
P/N: ACCSMNT, ARMSTS, STSCART
Material
Plastic, steel
AV Furniture
Mounting kit
Mounting Components
Articulating arm
Recommended Use
LCD display
Placing / Mounting
Desktop
Cable Management
Integrated cable management
12"-24"
Adjustments
Pan, tilt
Max Load Weight
5 kg
Adjustable height, portrait to landscape movement, swivel adjustment, gas-spring technology, pivot
9XDB StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.91
9XDB StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook In Stock £56.06
9XDB StarTech.com Articulating Monitor Arm In Stock £103.13
9XDB StarTech.com Monitor and Laptop Arm In Stock £88.19
Price Range Ex VAT: 50 - 100
