StarTech.com Heavy Duty 12U 2-Post Server Rack
Quicklinx: CLVJWS00 Mfr#: 2POSTRACK12
£117.64 ex VAT
£141.16 inc VAT
Store your server, network and telecom devices in this sturdy steel, open-frame rack. This 2-post rack stands on your floor or desktop to provide 12U of storage space for EIA-310-D compliant 19" rack-mount devices, such as telecommunication and A/V equipment. The rack creates a robust storage solution, with support for a total load capacity of 160 kg (350 lb.).
This compact 2-post mounting solution offers a small footprint, and it's engineered to provide exceptional stability, with a total weight capacity of up to 160 kg (350 lb.). The rack fits in virtually any environment, and can be positioned on any surface, such as your floor, desk or table.
The 2-post server rack comes in a flat-packed box to reduce shipping volume, which also significantly reduces your costs in shipping. The rack is packaged efficiently, so you can easily store it for deployment at a later date.
To help make your equipment install easier, this rack includes tool-less clip nuts that seamlessly work with the punched round holes featured on this rack. The tool-less clip nuts provide an easy-to-install nut, unlike square cage nuts which can be a hassle.
  • Save space and cost, without losing weight capacity
  • Save money, with a cost-effective, compact shipping package
  • Hassle-free hardware installation, with tool-less clip nuts
    To help make your equipment install easier, this rack includes tool-less clip nuts that seamlessly work with the punched round holes featured on this rack. The tool-less clip nuts provide an easy-to-install nut, unlike square cage nuts which can be a hassle. The 2POSTRACK12 is backed by a lifetime StarTech.com warranty with free technical support.
StarTech.com 12U Heavy Duty 2 Post Open Frame Network Rack - 350lbs - 19" Free Standing Desktop Rack for Computer, AV, Media, IT Equipment (2POSTRACK12) - rack - 12U
Rack
Rack Type
Open frame - 2-post
Package Content
4 rubber feet, right bracket, left bracket, top bracket, bottom bracket, 12 Phillips screws (10-32), 36 mounting screws (10-32), 36 clip nuts
Rack Size
19"
Height (Rack Units)
12U
Product Material
Steel
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
12U
Weight Limit
160 kg
Limited warranty: - lifetime
CLVJ StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £47.21
CLVJ StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.46
CLVJ StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £32.14
CLVJ StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £473.62
CLVJ StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
CLVJ StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £26.48
CLVJ StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £287.42
CLVJ StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £323.73
CLVJ StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
CLVJ StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £46.33
CLVJ StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £38.36
CLVJ StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £55.64
CLVJ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
CLVJ StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £40.38
CLVJ StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £49.33
CLVJ StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £18.29
CLVJ StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £24.18
CLVJ StarTech.com 19in Cable Management Panel In Stock £24.90
CLVJ StarTech.com Heavy Duty 12U 2-Post Server Rack In Stock £117.64
CLVJ StarTech.com 50 PKG 10-32 Screws & Nuts In Stock £31.95
