StarTech.com HDMI to VGA Adapter w/ Audio
Quicklinx: BGBWWS00 Mfr#: HD2VGAMICRA
Hurry, only 1 left in stock!
£13.93 ex VAT
£16.71 inc VAT
This highly-portable adapter is the ideal travel companion for your Chromebook or Ultrabook laptop. This HDMI-to-VGA adapter lets you connect your HDMI computer to a VGA display or projector. The versatile adapter features a discrete 3.5mm audio output for extracting stereo audio from your HDMI signal, and supports PC resolutions up to 1920x1200.
The adapter works with any HDMI equipped computer to add compatibility with VGA displays. Enabling VGA support on your Ultrabook or Chromebook means that you'll have the connection options you need to use almost any boardroom projector or display.
The HDMI-to-VGA adapter doesn't require software or drivers, which saves you time and hassle when you need to make a quick connection. Plus, the adapter features a 3.5mm output which gives you the option to share the audio directly from your HDMI port.
This compact HDMI-to-VGA adapter is lightweight and portable, and easily fits into any laptop carrying bag. The adapter has also been engineered with low-power architecture, so you won't need to carry a bulky external power adapter, or find access to an electrical outlet while you're on the go.
This converter will not output digitally encrypted content.
This converter is not compatible with Mac computers that use Intel HD 4000 cards (Mac Mini), for specific support for these devices StarTech.com offers the HDMI to VGA Adapter Converter (MCHD2VGA).
StarTech.com HDMI to VGA Adapter - Aux Audio Output - Compact - 1920x1200 - HDMI to VGA (HD2VGAMICRA) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm
2.1 cm x 6.23 cm x 1.25 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin HDMI Type A - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x audio line-out - mini-phone stereo 3.5 mm - female
FCC, RoHS
2.1 cm
6.23 cm
1.25 cm
14 g
Enclosure Colour
Limited warranty - 3 years
10 °C
BGBW StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p In Stock £14.07
BGBW StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
BGBW StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £6.03
BGBW StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
BGBW StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.99
BGBW StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £23.91
BGBW StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 In Stock £27.45
BGBW StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.52
BGBW StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £14.89
BGBW StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £7.68
BGBW StarTech.com 6ft HDMI to VGA adapter cable In Stock £20.67
BGBW StarTech.com HDMI to VGA Adapter w/ Audio In Stock £13.93
