StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080
Quicklinx: 8Y6GWS00 Mfr#: HD2VGAE2
More than 50 In Stock
£22.45 ex VAT
£26.94 inc VAT
Connect an HDMI equipped laptop, ultrabook, or desktop computer to your VGA display, or projector. The HD2VGAE2 HDMI to VGA adapter allows you to connect an HDMI output from your laptop, ultrabook, or desktop computer onto a VGA monitor or projector, saving the cost of upgrading to an HDMI compatible display. Intended for outputting user generated content such as presentations, and work documents, the HDMI to VGA converter can also work to increase your productivity by extending your computer's desktop on to a secondary monitor, doubling available workspace. This active HDMI to VGA adapter offers a compact and portable solution for connecting a High-Definition VGA display.
  • Efficient signal conversion
    The active adapter effectively converts HDMI signals to VGA, ensuring quality performance for video transmission between devices.
  • High resolution support
    With a maximum output resolution of 1920 x 1080, this adapter delivers sharp and clear visuals suitable for various applications.
  • Simple installation
    Featuring a Plug-and-Play setup allows users to connect devices with ease, eliminating the need for additional software or drivers.
  • Robust construction
    The durable plastic jacket ensures that the adapter can withstand regular use while maintaining optimal performance.
Startech adapter - HDMI / VGA - 24.5 cm
Cable
Adapter - HDMI / VGA
Max Output Resolution
1920 x 1080 - 60 Hz
Cable Length
24.5 cm
Connector
HDMI - male (input)
Connector (Second End)
HD-15 (VGA) - female (output)
1080p support, active adapter
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, SV211HDUC, SV221HUC4K
Cable Type
Adapter 1080p support, active
Interface Supported
HDMI / VGA
Jacket Material
Plastic
Cable Length
24.5 cm
Adapters & Converters
1920 x 1080
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - male (input)
15 pin HD D-Sub (HD-15) - female (output)
Plug and Play, FCC, RoHS, WEEE, REACH, RCM
4 cm
1.5 cm
35.3 g
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.5 cm
Shipping Weight
48 g
Limited warranty - 3 years
8Y6G StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £22.45
8Y6G StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 In Stock £23.53
8Y6G StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.48
8Y6G StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £6.77
8Y6G StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p In Stock £37.39
8Y6G StarTech.com 10ft HDMI to VGA adapter cable In Stock £35.26
8Y6G StarTech.com 3ft HDMI to VGA adapter cable In Stock £17.82
8Y6G StarTech.com 6ft HDMI to VGA adapter cable In Stock £20.60
8Y6G StarTech.com HDMI to VGA Adapter w/ Audio In Stock £12.88
