StarTech.com HDMI to VGA Adapter, 1080p
Quicklinx: J1LGWS00 Mfr#: HD2VGAE3
23 In Stock
£10.78 ex VAT
£12.93 inc VAT
  • Versatile connectivity
    This adapter allows seamless connections between HDMI output devices and VGA displays, providing flexibility for various setups.
  • High resolution support
    Delivering a maximum output resolution of 1920 x 1200 and supporting 1080p, this adapter ensures that visuals remain sharp and clear.
  • Convenient design
    The bus powered feature eliminates the need for external power sources, making it suitable for travel and on-the-go usage.
  • Durable construction
    Constructed with a PVC jacket and robust plastic housing, this adapter is designed for reliability and extended use.
  • Wide compatibility
    Compatible with a variety of HDMI and VGA devices, this adapter is well-suited for use in home theater setups, offices, and other environments.
